Timber
Timber
One of my first posts.
First, I only wanted to get my exhaust welded and cleaned up. Along the way decided to clean the headers as well.
Welded exhaust, cleaned it and cleaned the headers IMG-20131001-00607
Welded exhaust, cleaned it and cleaned the headers IMG-20131001-00604
Welded exhaust, cleaned it and cleaned the headers IMG-20131001-00606
MikeP
MikeP
Nice, neat job. The only thing I'd have done differently is to use copper nuts on the header studs (much easier to deal with later).
Welded exhaust, cleaned it and cleaned the headers K1%20BMW%20%28170%29-L
1992 K1
looks great timber ,,,,,well done !
"Nice, neat job. The only thing I'd have done differently is to use copper nuts on the header studs (much easier to deal with later)."
Best thing to use is all Titanium nuts and bolts. I used to get hold of loads from the Tornado aircraft in my last job and they are never affected by heat or corrosion.
MikeP
MikeP
bikerboy wrote:Best thing to use is all Titanium nuts and bolts. I used to get hold of loads from the Tornado aircraft in my last job and they are never affected by heat or corrosion.
I wish that you'd owned this K1100 at some stage then. Despite plenty of heat and soaking the second nut I've tried has just sheared the stud.
Sad
1992 K1
Ghost who rides
Ghost who rides
Good pics especially the last one, don't see that view normally.
Correct me if i'm wrong but brass was the NUT of choice ?
My old 1952 International truck, no history, was the GO!
Fine thread, steel nuts. I am the biggest Slammer of American tech, bar none,   call me a convert!
IF,  IF,  you want the best, custom your exh studs, fine thread for the pipes, with neverseize etc.
never be a problem again IMHO.
Nice timber, Can you do mine next please Laughing
Welded exhaust, cleaned it and cleaned the headers Ir-log1188....May contain nuts!Welded exhaust, cleaned it and cleaned the headers Ir-log11
K75RTP - 1994
klamityboy
klamityboy
Very Nice. What did you use to polish the exhaust?
Klamityboy
1991 K75RT-P
Model Description: K 75RT
Market: Europe
Type: 0565
E-Code: K569
Engine: 3_ZYL - 0,70l (55kW)
Transmission: Manual
Body Color: Polizeiweiss
Production Date: 30.08.1990
bikerboy wrote:"Nice, neat job. The only thing I'd have done differently is to use copper nuts on the header studs (much easier to deal with later)."
Yes Bikerboy, I still have the screw you gave me last summer..... Light, strong and expensive Smile
As Ghost who rides stated, neverseez is the best and cheaper treatment that you can give to you exhaust nuts and studs. I used it in a lot in marine environment where salty water and heat are corroding any screws.
CF
Welded exhaust, cleaned it and cleaned the headers Frog15Welded exhaust, cleaned it and cleaned the headers Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
Shep
Shep
Please clarify which Never Seez product should be used on the exhaust system?
Shep
the.postman
1984 srx 600
1986 cbr1000f/h
k-rider
k-rider
nice job, you must have cleaned the cylinder head too ?,did you use a wire brush and autosol for the headers?
Timber
Timber
I used a wire brush on the headers and diesel and a toothbrush to clean the rest before re-installment.
