1 K75C project - sort of runs. Thu Mar 09, 2023 8:57 pm
Rockman
I bought this 1987 K75C off a mate as a restoration project and for this year's Scrapheap Adventure Ride. Non-goer of course, in fact nothing worked but it would turn over if the starter solenoid was shorted across the terminals.
Nothing seemed to be too far wrong so I set about disconnecting and reconnecting things. This worked, it turns over, has lights etc and spark. Radiator has a pinhole but I've got another one coming so all good there.
Next step was to get it to run. New el-cheapo injectors from our friends in China ($48 for a set of 6). Still wont go. Sit and have a look for a while. Aha - spark plug leads are the wrong way around. Fix that and it goes - sort of. Its running on about 2 1/2 cylinders. No. 1 sort of backfires to the point that I can see flame around the intake where the arrow is on the photo below. The rubber is split which probably doesnt help. I'm wondering if the intake valve on this cylinder is sticking a little and not closing fully. It seems to run ok at around 2000-5000 but that might be an illusion. Any suggestions??
