1Back to top Go down   speedo not working Empty speedo not working Tue Oct 27, 2009 6:48 am
sandman jim
hi..just bought 1986 k100rs...(( bike been stood since 2001)) rev counter works fine but i have no speedo reading the needle does not move at all.. any ideas what i should check first please... kind regards jim speedo not working Icon_smile speedo not working Icon_smile speedo not working Icon_smile
2Back to top Go down   speedo not working Empty Re: speedo not working Tue Oct 27, 2009 2:27 pm
Bruce
Bruce
Hey! I have an 86 K100RT and had the same problem, make sure all connections are clean from the final drive pickup through into the instrument panel. Lots of problems with this design, plenty of fixes listed here too, but I found that my final drive pickup was shot, and replaced it for 40 bucks, works like a charm! good luck!
3Back to top Go down   speedo not working Empty Re: speedo not working Wed Oct 28, 2009 5:42 am
Bones
Hi There,
I had the same problem and it turned out that a good clean with a cloth of the sender unit in the final drive was all that was need to get it working again
B
4Back to top Go down   speedo not working Empty Re: speedo not working Wed Oct 28, 2009 6:59 am
It could be your pickup sensor on the differential, but first try to tap on your speedo when riding. If it starts working, the problem is in the cluster.
The most common problem is corrosion on the contacts inside the instrument cluster. You have to open it and clean the contacts indicated by the red arrow.
On the download section you can find a very good page explaining how to open the speedo.
speedo not working Speedo10
speedo not working Frog15speedo not working Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
5Back to top Go down   speedo not working Empty Re: speedo not working Wed Oct 28, 2009 5:11 pm
sandman jim
Crazy Frog wrote:It could be your pickup sensor on the differential, but first try to tap on your speedo when riding. If it starts working, the problem is in the cluster.
hi..checked sensor in diff it was clean as anybody got a picture of one taken out so i can compare please...regards jim speedo not working Icon_smile speedo not working Icon_smile
