1Back to top Go down   Valve cover bolt rubber washers Empty Valve cover bolt rubber washers Sun Jul 21, 2013 5:25 pm
ironbutt
ironbutt
Anyone enlighten me on the rubber washers that go on the valve cover and crank case cover bolts. The ones my BMW dealer got me don't seem to be correct. Those bolts have a shoulder on them and it would seem to me that the washer would cover that area but it doesn't. And the bolts tighten then stop. Don't want to get this together and it leaks. Any input would be appreciated.
Valve cover bolt rubber washers 1106080553
85 K100rs WB 1051307F0040102
2010 Camaro SS
2Back to top Go down   Valve cover bolt rubber washers Empty Re: Valve cover bolt rubber washers Sun Jul 21, 2013 5:36 pm
They should look like this:
Valve cover bolt rubber washers Paknin10
3Back to top Go down   Valve cover bolt rubber washers Empty Valve cover bolt rubber washers Sun Jul 21, 2013 5:53 pm
ironbutt
ironbutt
Any chance you could post a pic of the other size?
2010 Camaro SS
4Back to top Go down   Valve cover bolt rubber washers Empty Re: Valve cover bolt rubber washers Sun Jul 21, 2013 7:36 pm
Valve cover bolt rubber washers Paknin11
5Back to top Go down   Valve cover bolt rubber washers Empty Re: Valve cover bolt rubber washers Sun Jul 21, 2013 8:13 pm
The bolts tighten against a shoulder so that they cant be pulled down so hard that the gasket gets squashed and destroyed and leaks.
6Back to top Go down   Valve cover bolt rubber washers Empty Valve cover bolt rubber washers Sun Jul 21, 2013 11:43 pm
ironbutt
ironbutt
Thanks Inge for the pics. I got the right ones.
 Thanks Rick for esplanin the bolt, I just thought the rubber washers were to shallow and not taking up the gap. Put the tank back on and tried to start it...ran 10 secs then died. Did it 3 times same thing...started thinkin the worst...fuel pump gone bad...turned the shop radio off and tried it again to listen for the pump...she whined on the shut down... open up the tank and shined my flash light in...OMG...NO GAS!!! ...2 gallons of British Petrolium Premium and she fired right up...imagine that!! No leaks on the valve cover or crank cover (new gaskets and rubbers all around). Tomorrow evening I'll mount the cluster and fairing, check the lights then nothin left but to pack my pannier and be ready to head to New England 3 a.m. Thursday. Hope to make it to Collinsville, Ct. by 1 p.m.  621 miles door to door. Again my thanks to ya'll for answering all my question and posting such great and useful information on here. Can't wait to try the K with the TPS disconnected!
See ya out on the road
2010 Camaro SS
7Back to top Go down   Valve cover bolt rubber washers Empty Re: Valve cover bolt rubber washers Mon Jul 22, 2013 8:31 pm
cruise_carter
cruise_carter
one thing with those little rubber gaskets, no more than 5 ft lbs of torque to tighten.
If they get crushed down, they will leak
Currently on the hunt for another old K bike (K100RS would be perfect)
2004 R1200CLC (gone recently......those evo brakes are brutal)
1985 K100RT, lots of km but lots of life left (gone)
2002 HD Electra Glide Classic (gone)
1987 K100RS (gone)
2002 HD Road Glide (gone)
2000 R1100R (gone)
lots more in the past........
8Back to top Go down   Valve cover bolt rubber washers Empty Valve cover bolt rubber washers Tue Jul 23, 2013 4:44 pm
ironbutt
ironbutt
Good to know. My book said 7lbs. but I heard my elbow click at 5. :DI have yet to get a torq wrench that goes down that low.
2010 Camaro SS
