1Back to top Go down   K75 Fuel Pump Question Empty K75 Fuel Pump Question Tue Jul 02, 2013 8:52 am
weez
weez
When pulling off the fuel hoses on bottom of tank is it normal for gas to continue coming out of the pump discharge to fuel rail connection?
I understand there's a built-in check valve in the pump but mine will keep flowing gas, siphoning I would guess, unless I either drain the tank down low enough or tilt the tank over to stop it.  I've had the bike since '87 and I've had the tank off countless times and IIRC it would usually dribble a little and then completely stop. It seems this started when I put a used pump in last year so I'm suspecting the check valve is stuck and/or not operating correctly. The pump seems to work fine otherwise.
1987 K75T 326K aka Uncle Fester.
2000 KLR 685
2000 KLR 650
1997 ST1100
2000 DRZ400E
2Back to top Go down   K75 Fuel Pump Question Empty Re: K75 Fuel Pump Question Tue Jul 02, 2013 10:32 am
When I pull the hoses off I always open the filler as that prevents a pressure build up which will force the fuel out.
Othere here place a piece of fuel line from inlet to outlet and so seal the tank off.
3Back to top Go down   K75 Fuel Pump Question Empty Re: K75 Fuel Pump Question Tue Jul 02, 2013 3:53 pm
walfish
walfish
I use a Golf tee on each hose as a plug.
Dig your old golf bag out from the shed, plenty there.
Last edited by ungaas on Tue Jul 02, 2013 3:57 pm; edited 1 time in total (Reason for editing : Clarity)
K75 Fuel Pump Question Uk-log10
                            88 K 100  0033026 (gone)
                            92 K 1100 LT  6455097 (gone)
4Back to top Go down   K75 Fuel Pump Question Empty Re: K75 Fuel Pump Question Tue Jul 02, 2013 4:49 pm
the check valve is on the return line
just so you know
5Back to top Go down   K75 Fuel Pump Question Empty Re: K75 Fuel Pump Question Tue Jul 02, 2013 5:15 pm
charliebarnwell
charliebarnwell
I seen on youtube - start the engine and whilst running disconnect the fuel pump connector behind the right hand side panel and after a couple of seconds the engine stops coz there is no fuel getting through and all the pressure is used up.
https://www.youtube.com/watch?v=od4r7SoIPRo
goto about 2 minutes into the vid
6Back to top Go down   K75 Fuel Pump Question Empty Re: K75 Fuel Pump Question Tue Jul 02, 2013 10:49 pm
weez
weez
Thanks for the info and tips everyone.
2000 KLR 685
2000 KLR 650
1997 ST1100
2000 DRZ400E
