1 Electrical Problem - Not Cranking Sun Jun 16, 2013 5:29 pm
Shug
Hello,
I'm hoping someone can point me in the right direction.
K100RS 1983.
Went out for a spin when the charge light came on brightly. Bike seemed to be running fine, but I headed straight home. The neutral light didn't work though headlights, indicators and horn did.
Turned the bike off when I got home but when I turned it back on there is no neutral light and the bike wont turn over even when I pull the clutch in.
The bike has been showing a dim charge light off and on for some time and after checking the forum this appears to be fairly normal.
The bike has stalled a couple of times when approaching traffic lights but started on the button no issues.
There is a new battery fitted, which I've checked and seems to hold it's charge fine.
So far:-
Checked the battery connections - cleaned.
Checked the earth point under the tank - cleaned.
Ignition switch seems to be ok
Kill switch ok
Clutch switch ok
Took starter motor off and got rid of the worst of the dust/debris inside.
Took the Alternator brushes out and these seem ok for length.
Took the clocks off and checked the Neutral bulb, 12v gives a nice bright light.
When turning the ignition on there is a relay that clicks in.
Hopefully someone can help, bike is laid up and were seeing some great days to be out for a ride.
Thanks in advance.
Shug
K100RS 1983.
So far:-
Kill switch ok
Clutch switch ok
Thanks in advance.
Shug
