1 Need some measurements??? Nice please? Sun Oct 04, 2009 9:01 am
ReneZ
All, I need some help. I have noted that my battery drains. Measuring over the fuse sockets it seems to come from the 'clock/indicator' fuse. The current is 5.6 mAmp. It is not the clock (had the speedo disconnected). To know if I have an issue or not I would highly appreciate some of your measurements. If you could be so kind to pull the corresponding fuse and measure the current draw and list it here I would be gratefull. None of the other fuses indicate, so it must be something to do with this one. I have already replaced the indicator relais, but the result is the same. I'm wondering if I have a minor short somewhere.
So if I can please have some measurements? THANKS!
Greetings from
Rene
BMW K100 - 1985 (0030029) Scotland
