1Back to top Go down   Gear Change LCD Fix Empty Gear Change LCD Fix Tue Jun 11, 2013 11:34 am
I got a 2nd hand LCD from motorworks to replace my bleeding one. I stripped the panel apart and got the old LCD out, and the replacement is missing a contact foot.
I've had a winge and asked for a refund, $15 postage for god sake, but can I make a good one from these two?
Has anyone split the plastic before to get to the components? Can it be done?
I'll get a better image later.
Gear Change LCD Fix LCD-1
Gear Change LCD Fix LCD-2
Gear Change LCD Fix LCD-3
2Back to top Go down   Gear Change LCD Fix Empty the missing Tue Jun 11, 2013 11:53 am
ibjman
ibjman
the part should just almost fall out the slot in the back. do not take the shell apart. it's just a little square rubber wafer....slides right out & back in....they often fall out & easy to loose. Probably should save the other one too before discarding the old display.
I don't know how they work but they do!
3Back to top Go down   Gear Change LCD Fix Empty Re: Gear Change LCD Fix Tue Jun 11, 2013 12:03 pm
those rubbers are a carbon impregnated series of layers of silicon they act as minature wires in a planar direction ,
should be swappable without isssue but be carefull not to clean off the carbon areas too much ...else you might get a segment not working too good ....
but do clean up the copper pads on the circuit board that they attach to ....its just a presure fit
hope that helps
4Back to top Go down   Gear Change LCD Fix Empty Re: Gear Change LCD Fix Tue Jun 11, 2013 12:16 pm
Got it. Thanks guys. A little prompting with a sowing needle and one popped up and I moved it over. I wonder if they'll send me another one Cool
Most likely they'll just ignore me completely What a Face
5Back to top Go down   Gear Change LCD Fix Empty I Love It! Tue Jun 11, 2013 12:22 pm
ibjman
ibjman
I love it when things get "solved" here!
6Back to top Go down   Gear Change LCD Fix Empty Re: Gear Change LCD Fix Tue Jun 11, 2013 1:42 pm
I may have moved the carbon rod but I won't know if it will work for weeks.
So many parts coming, so far to travel Sad
I also see the bad LCD just dropped out of the plastic holder once I loosed the carbon rods.
Surely the LCD's can be bought and replaced on their own. I'll look around.
7Back to top Go down   Gear Change LCD Fix Empty Re: Gear Change LCD Fix Tue Jun 11, 2013 2:22 pm
been looking for a while robin...havent found a supplier yet
good luck ....if you find one, there are many that would appreciate the info (manufacturer )
8Back to top Go down   Gear Change LCD Fix Empty Re: Gear Change LCD Fix Tue Jun 11, 2013 7:02 pm
Might want to check out what's available from E-ink.
http://www.eink.com/display_products_aurora.html
This is the display technology used in e-readers like Kindles, Nooks, and similar. I see that they have a segmented display which would be useful as a gas gauge. They make simple three element 7-segment display modules as well. The beauty of the e-ink technology is that it is easily readable in daylight, at night with artificial light and can retain an image with power removed. They are also extremely thin and take negligible current to operate.
E-ink sells a segmented display starter kit that has all the parts for experimenting with e-ink technology
9Back to top Go down   Gear Change LCD Fix Empty Re: Gear Change LCD Fix Tue Jun 11, 2013 8:43 pm
cool...!
thanks rob
10Back to top Go down   Gear Change LCD Fix Empty Re: Gear Change LCD Fix Thu Jun 13, 2013 9:57 am
Well strike me pink and blue, they are sending me another LCD   Shocked
Squeaky hinge syndrome .... Gear Change LCD Fix 447221
11Back to top Go down   Gear Change LCD Fix Empty Re: Gear Change LCD Fix Thu Jun 13, 2013 7:48 pm
gpguyer
gpguyer
Gotta love this forum for the friendly advice you get and the friends you make.
12Back to top Go down   Gear Change LCD Fix Empty Re: Gear Change LCD Fix Fri Jun 14, 2013 5:34 am
Erman
Erman
Would it be possible to use similar parts from cheap calculators?
Bikes:
1984 BMW K1000RS
1984 Yamaha XJ750 Seca
