1Back to top Go down   Fork oil grading Empty Fork oil grading Fri Aug 02, 2013 8:00 am
coopz
coopz
Just about to change fork oil first time for me with the BM and wondering if anyone has mixed their own. I've used previously 10/30 motor oil 50/50 with transmission fluid grade is around 10 I think would just trans oil be ok as I've used this many time in XS 1100 bikes with no trouble Coopz
1985 K100 RS
2Back to top Go down   Fork oil grading Empty Re: Fork oil grading Fri Aug 02, 2013 8:24 am
The BMWs are very touchy on the grade of oil used in the forks. I have used auto trans fluid but it comes up a bit hard. Most of the guys here seem to use the fork oil from bike shops and 5 or 7.5 and some use 10 it is just a matter of what feels right.
3Back to top Go down   Fork oil grading Empty Re: Fork oil grading Fri Aug 02, 2013 8:54 pm
japuentes
japuentes
Hi there, for pothole infested roads 10 is too hard and ATF will bend your rims, 5 works fine.
Best regards
JAP
Fork oil grading 2854237993 1988 K100RS SE/ABS
4Back to top Go down   Fork oil grading Empty Re: Fork oil grading Sat Aug 03, 2013 7:48 am
I used 7.5 as I was not sure what to put in, but I am happy with it.
5Back to top Go down   Fork oil grading Empty Re: Fork oil grading Sat Aug 03, 2013 8:54 am
japuentes wrote:Hi there, for pothole infested roads 10 is too hard and ATF will bend your rims, 5 works fine.
Best regards
JAP
Sounds like your roads are as bad as the roads here.
6Back to top Go down   Fork oil grading Empty Re: Fork oil grading Sat Aug 03, 2013 9:45 am
I tried 10 and changed to 5. It seems to work for me.
7Back to top Go down   Fork oil grading Empty Re: Fork oil grading Mon Aug 05, 2013 11:32 pm
k75RT Keith
k75RT Keith
Running 7.5 in my RT.  Had 15wt in the fork and it was like having no suspension.
It should be noted that fork oil weight ratings are not standardized or regulated.  That is to say there is a very wide range within a specific weight.  One brand of 10wt may be heavier than another.
8Back to top Go down   Fork oil grading Empty Re: Fork oil grading Mon Aug 05, 2013 11:56 pm
Basic2
Basic2
I'm using Motul 10W in my Basic/2 and it seems a good balance for me.
K100 Basic 2
11/1987 6308319K100CJ
Marakesh Red
9Back to top Go down   Fork oil grading Empty Re: Fork oil grading Tue Aug 06, 2013 8:46 am
zonenfeile
zonenfeile
7,5 for the 75
10 for the 100
5,0 : to be used for salad only
for final adjustment:  +/-  10-20ml
best results with that if "comfort" is still wanted
ex K1100/2
K- Wiki - or rtfm first
Regards from Hamburg
Olaf
10Back to top Go down   Fork oil grading Empty Re: Fork oil grading Tue Aug 06, 2013 10:28 am
Fork oil grading 44271 Fork oil grading 44271
11Back to top Go down   Fork oil grading Empty Re: Fork oil grading Tue Aug 06, 2013 11:22 am
Kioors
Kioors
Using 10W on my RS too.
First time I put new oil in the forks, I was still a bit daft, and filled 'm right up. Next I rode out trough the gutter into the street and had a bit of an ego-dent as my father stared laughing out loud... 🤡 Rolling Eyes
=> measure! It works best with a big syringe, since the oil doesn't stick in it, and you don't pour it all over the garage floor.
1989 K100RS 16v
1991 K100RS 16v - For sale
1993 Ducati 750 SS - For sale
1992 Ducati 907i.e.
