1Back to top Go down   interesting fork modification Empty interesting fork modification Fri May 17, 2013 3:07 am
If you cannot afford a leading link fork, here is a simple cheap modification. Very Happy
This is an original modification made by AJF Axion.
interesting fork modification Deport10
interesting fork modification Dsc00310
interesting fork modification Frog15interesting fork modification Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
2Back to top Go down   interesting fork modification Empty Re: interesting fork modification Fri May 17, 2013 6:42 am
Struth that showed up the difference didnt it, hope it handled well enough to warrent the work
3Back to top Go down   interesting fork modification Empty Re: interesting fork modification Fri May 17, 2013 6:06 pm
Yes, very interesting, CF.
On a K the front wheel spindle needs to move forward between 50 and 70mm and I've been doing some sketches of a similar arrangement for a K but, as yet, I haven't come up with a good (simple?) design. Swapping the fork legs over is the first step......to put the caliper mounts at the front. Then it should be easy enough to make some caliper mounting plates. Sorting the wheel axle mounts is rather more tricky though.
4Back to top Go down   interesting fork modification Empty Re: interesting fork modification Fri May 17, 2013 6:45 pm
it would be interesting to see the additional wear to the forks with that amount of offset forward .
just a thought
5Back to top Go down   interesting fork modification Empty Re: interesting fork modification Fri May 17, 2013 7:55 pm
sidecar paul wrote:Then it should be easy enough to make some caliper mounting plates. Sorting the wheel axle mounts is rather more tricky though.
The calipers can be mounted the same way as it is on the EML.
The mounting plates have a bearing and are rotating on the wheel shaft.
If the weather cooperates, I will try to take pictures tomorrow.
I believe that you can do the whole assembly without turning the forks. The original caliper mounting hole would only be used to attach the extension.
The only major modification would be a longer wheel axle.
Let me find some free time and I will try to sketch something for you. (I have some ideas)
Many heads working on the same project can lead to an easy solution. Very Happy
I already have a leading fork, but designing something to modify the original fork interest me.
CF
6Back to top Go down   interesting fork modification Empty Re: interesting fork modification Sat May 18, 2013 4:32 pm
CF
Exactly my feelings,
7Back to top Go down   interesting fork modification Empty Re: interesting fork modification Sun May 19, 2013 5:15 am
Just so I get this right, you are talking of using the left leg in the right and right in the left that is pull em both out and turn em over and put em in then fabricate the fork extension. if that is right and you add the callipar mounts to the fork extension then all that is needed is for longer brake tubes fron the flexible hose to the new calipar location, am I on the same page as you blokes yet????
8Back to top Go down   interesting fork modification Empty Re: interesting fork modification Sun May 19, 2013 5:47 pm
K75cster wrote:Just so I get this right, you are talking of using the left leg in the right and right in the left that is pull em both out and turn em over and put em in then fabricate the fork extension. if that is right and you add the callipar mounts to the fork extension then all that is needed is for longer brake tubes fron the flexible hose to the new calipar location, am I on the same page as you blokes yet????
More or less, but sidecar blokes do go to some weird pages. scratch
Swapping the legs over just provides some mounting points at the front as can be seen on CF's initial pics.
9Back to top Go down   interesting fork modification Empty Re: interesting fork modification Sun May 19, 2013 5:53 pm
Here is a pic of the EML brake calipers. This could give you some ideas.
The support is mounted on the wheel shaft.
To modify an original fork:
If the piece to bring forward the wheel axle was a U shape type, the problem would be solved.
The way that I see the piece to bring the wheel forward: It should be attached to the original holes holding the caliper and a 'stub' the size of the wheel shaft should be welded on the bracket and inserted in the bottom of the fork . This way you have a 3 fix points of contact for the extension.
I will sketch that later.
interesting fork modification Dsc_2419
