1Back to top Go down   New Member Empty New Member Fri Jun 14, 2013 5:46 pm
albomoto
albomoto
Hi, I'm new the the forum and happy to now own an 87 K100 RT. I bought the bike with 25k on it and have since put on another thousand. I just had to pull out the throttle cable since it ceased on me and I'm now having to replace the center stand. It looks like I might have to pull the exhaust to get the left side bolt out. Anybody run into this? I have more plans for the bike down the road and I'm excited to be a part of the community.
2Back to top Go down   New Member Empty New Member Fri Jun 14, 2013 7:46 pm
Welcome albomoto
that's a low mileage bike you have there, nice buy.
I haven't had my centre stand off this bike so can't help, although I was under the impression that the 4 attaching bolts were
easily accessible from underneath.
Don't forget to check all the hoses and connections, it's still an old machine.
3Back to top Go down   New Member Empty Re: New Member Fri Jun 14, 2013 8:08 pm
RT wrote: Welcome albomoto
+1.
RT wrote: the 4 attaching bolts were easily accessible from underneath.
Easier than messing with the exhaust...the bolts is secured with loctite,
some heat could be needed.
4Back to top Go down   New Member Empty Re: New Member Fri Jun 14, 2013 8:34 pm
krambo
krambo
Welcome from the UK albomoto Wink
"Aut viam inveniam aut faciam." New Member Uk-bmw12
http://www.its-personal.net
5Back to top Go down   New Member Empty Re: New Member Fri Jun 14, 2013 8:35 pm
Hi Albomoto welcome to the forum.
I have to agree with the others about taking the 4 bolts that secure the whole stand mechanism. You will need to secure the bike upright so as to do it as the side stand also comes with the rest.
If you go to the portal page and have a read of the "you just bought a k100 so what now" page you will get some good info for new owners.
6Back to top Go down   New Member Empty Re: New Member Sat Jun 15, 2013 2:02 am
MikeisonTV
MikeisonTV
Welcome....there are some very helpful guys on this forum....And there's Rick G too :0
7Back to top Go down   New Member Empty Re: New Member Sat Jun 15, 2013 1:04 pm
brickrider
brickrider
Welcome from Idaho, Albo.  With the info and helpful experts here you'll have that old/new bike in good order in no time.
8Back to top Go down   New Member Empty Re: New Member Sat Jun 15, 2013 8:48 pm
albomoto
albomoto
Thanks all for the info! I've been seeing some owners replacing the center stand with k1100 stands because they're more strong and durable. I think I'm gonna look that direction.
9Back to top Go down   New Member Empty Re: New Member Sat Jun 15, 2013 8:50 pm
albomoto
albomoto
Oh, and I'll be sure to post pics. I've been thinking of repainting the bike a bright metallic green and black. Kinda like the new Mustang Boss 302s. I think it would look sharp.
10Back to top Go down   New Member Empty Re: New Member Sat Jun 15, 2013 9:01 pm
albomoto
albomoto
I've found some old, cracked rubber that I can easily replace. The breather hose for one. I was going to also look at replacing the air filter but the top portion of the airbox has a wire going to it for a sensor, maybe mass air flow. The manual doesn't mention how to disconnect  it and the filter is stuck in pretty good from sitting in there all these years. The collector tube isn't liking to free itself either. I think I'll leave it until it becomes a problem.
  I also had to change out a spark plug and did so with an Autolite plug. The local parts store didn't have any Bosch plugs. I've replaced the cream seat with a Corbin seat, more form fitting and looks a lot better. I also had to pull the throttle cable because it started sticking. The cable had to be ordered from the dealer.
11Back to top Go down   New Member Empty Re: New Member Sun Jun 16, 2013 1:34 am
Good to have you on board, you have started farkling already Very Happy
