well bert 2.0 has put together a few of his modded exhaust pipes now ....and he is finding some new and interesting things along the way .
but for us guys, the sound out of the "k" is a beutifull thing
so far amongst our mob, there is
bert 2.0 ( bert2 special)
alby (bert2 special)
saxon 7 (bert2 special)
charlie 99 (staintune )
klompy (staintune )
two wheels better (motad )
all with a great noise coming out the rear ....not so loud as the open pipes of days gone by ....but a solid thump and crackle kinda thing ....turn heads indeed .
the performance benefits are immediatly noticeable ...and the "grin " soon follows after fitting one
onya bert ....there are a lot of smiles around this area of aussie
this prompts me to start some investigation into mixture settings and adjustments to get the best from our old girls
namely an oxygen sensor thingy to get the mixtures right,
so if anyone knows the technical (electronically and physical ) of making such a device please chime in .
im not enchouraging anybody to buy one ...unless there is some kind of cheap adaptor availabe to suit a good digital multimeter .
i was thinking of trying to develop a 2 wire ox sensor (out of a car ) and making some form of electronic output to a digitalmeter to get near a better stolich mix value by adjusting the afm etc ..
col
col
charlie
kart racers use a thing called ezy tune, i actually have one on my kart
oxy sensor from commodore ( all had to do was drill hole in exhaust and weld on nut)
it comes with leds that change from orange (to rich) to green (right )to red (to lean )i will have a look later and if i get this computer fixed post pics
1991 k100lt "the enterprise"
wngnutmv
wngnutmv
I haven't owned my K long enough to want to change anything, except the exhaust, which I think is ugly and just a little too quiet. I don't want it obnoxiously loud but would enjoy a little "thump". I just haven't been able to find any good links for aftermarket mufflers. Where do you guys find yours and do I need to consider fabrication of a 4 into 1 adapter. Sorry if this is a little off topic.
Mike
"Wingnut"
85 K100RT (VIN 0D50672) 70,000+miles
"Gretchen II" (Gretchen von Gearshiften)
Albyalbatross1
Albyalbatross1
HERE is one that pops up now and again..
caferacer62
caferacer62
Awww Charlie such nice things you say. Mate i just can't leave anything standard, even the mower gets worried.
Its a piece of cake to put the O2 sensor on the pipes. Could be done on the bike, all you need do is drill a 20 mm hole and tig weld an 18mm x 2(i think its a 2mm pitch) nut on and O2 sensor screws straight in. All you need do is get an 18mm set bolt(the thread goes all the way up to the head) to screw in the hole when o2 is not in use.
Then we can check the stoichometric values of the tune. Cant wait for someone to get one of these tuney thingos happening(charlie,alby? resident electro boffins)
Wngnut i think someone on here somewhere has made an adaptor for their bike, just cant remember who.
Bert 2.0
zorsts ---- old boys and young mans toys ? 170874
Wngnutmv,
You'd be surprised how un-ugly they become when they start to sound right. zorsts ---- old boys and young mans toys ? 8157
yeah kinda along the thinking bert but
im thinking portable ...not just for gerty or any one in particular ...
from what i have read
1> they need to get to about 600 degrees to work properly
2> the output varies from about .1 volt (100 milli volts ) up to about 1 volt
3> i need some kind of "calibrated" meter
so my thinking is along the lines of a temperature controlled heater ( i got just the idea ...out of a temp controlled soldering iron )
some meter mechanism ....thinking a real cheap digital meter a bit of a power supply to run the electronics ...i guess a 5 volt reg and a pull up resistor
a sampler tube to project down the throat of whatever zorst were testing which fitts up to the ox sensor and heater ...and an air sucker pump that draws the exhaust gasses up to the sensor along the tube
so i guess the sensor would need to be made fit the sampler tube ...with heater inside ..(probably wrapt around the ox sensor) and a bleed tube off that to suck up the sample ....
would all have to be welded up though ....so i fail there unless i can make it in a little cabinet and isolate the heater etc in some small sealed enclosure
hey col i like that idea ...i have seen some projects in jaycar that are verry similar ....in fact i might go revisit that idea soonish ...
but im looking for a absolute value ...not a good - bad - bad solution , im hopeing we can get enough accuracy to measure down to .25 % increments .....my thoughts with the digital meter was to run up a truth table in comparison with a real working high tollerance unit ....like the guys that fitt gass conversions to cars ....but some of them do parts per million stuff ...so id have to learn the jargon and the meanings first i guess
my hopefull end result is that we can all acheive a nice brown output rather than the typical black sooty end cap ...from too much unburnt fuel through the motor
well is worth a thought i guess
that guy who modded the k in holland did a collector bert you know the one that had the cut up rs fairing in white and all the straight lines front to back
but the "equall length " header pipes is an interesting idea also .. i think that is motad also ....whether still in production is another mystery
caferacer62
caferacer62
Good thinking Charlie, when i was working at a place that had a dyno we had a tube that went up the tailpipe that monitored exhaust gas. It had a five wire O2 sensor attached to it which in turn connected to a laptop. The five wire sensors already have a heater built into them as do the four wire ones I think.
Very often we would go for a drive around the streets with the snoofle(thats what we called it) attached to the exhaust and hooked to a laptop. Worked really well. Now it was a Dyno Dynamics dyno but I'm sure you could do it without that specific tuning software. The snoofle is easy to build.
I am guessing that one of you guys who knows their way around a computer program or two could figure this out.
Now all I need to build is a set of rollers that we can strap the bikes to. Hmmm another project I feel.
Oh could Inge or someone tell what an exhaust came off from a part number. Its Gillet 3887 18121454918. Thats the number off the ones I got from Saxon, with the very open chambers. I seem to have misplaced my end cap so cant compare the numbers. Maybe Alby could check his to see what the different part no is.
Oh by the way Col yours is nearly done too.
Bert 2.0
yeah your right there bert
but the 4 wire types are what they call narrow band sensors .... but maybe just the job for this cause /
ill invesigate that further ......but will keep an eye on cost ...
i guess ill need to builld an a to d converter etc for the puter huh ?
caferacer62
caferacer62
I can use my contacts to get a sensor when needed. We used to use General Bearings as they are a Bosch dealer and also sell their own brands of Injectors and associated parts and are reasonably priced too. Always good to know.
Bert 2.0
GerryP
GerryP
This all sounds much too complicated for an old man like me.
I think I'll content myself with looking at colour of a spark plug occasionally zorsts ---- old boys and young mans toys ? 8157
I remember when sonny...
Safe riding Cool,
Gerry Parnham
K1100LT (1993) in Silk Blue/Cream
http://gerryparnham.com
When I used to drag race we attached thermocouples and this allowed a very accurate indication of fuel mixture and total performance.
Heat is horsepower they say....until of course when too lean and then its just cost.
But this method made tuning at any rev reading very easy..
KKlompy zorsts ---- old boys and young mans toys ? 2854237993
zorsts ---- old boys and young mans toys ? Au-log10
JimK
JimK
...still trying to figure out the Supertrapp exhaust literature that I got along with the bike is about.
Was told that it had one of these on it. Can't see anything special down there.
Is quiet when at 3-4 k rpm....bike just whirrs and chirps happily along.
Twist of the wrist above that and it honks loudly when into it and downshifting .. Gets attention.
Folks want to know WTF?
Me too. Very Happy ...but wasn't going to share that with them.
'89 k100 rs se
Klompy wrote:When I used to drag race we attached thermocouples and this allowed a ver accurate indication of indisputable mixture and performance
hmm whats that all about klompy ?
i guess in drag racing your trying to get as much fuel through the system in the shortest time possible ....after all its just a pump of sorts ...just have to make it burn well under those circumstances ...no ?
im going the other way ....well of sorts ...to find the best blend of fuel versus economy , concidering what we have planned , more flow , the zorst is just the output, im intending of getting rid of the 9 direction changes through the inlet manifold path and i dont think the metering will be correct for those mods ...call it a less restricted pump ? this could change the torque characteristics somewhat, but im guesing the high mass revolving round will keep it all mooving in the right direction ...well see... its easy to step backwards if it all goes to brown goo . should have a keen induction noise as well ....grin
charlie99 wrote:[ im intending of getting rid of the 9 direction changes through the inlet manifold path and i dont think the metering will be correct for those mods ...call it a less restricted pump ?
Every turn is worth a specific pressure drop (certainly in exhaust technology)....theoretically if you have enough turns in a pipe, you wont get any pressure out the other end.
I do believe that the lengths and diameters of primary and secondary exhaust extractors/headers have a marked effect on where power is delivered, and also if there is no back pressure there is less efficient burn.
Sounds a like a fun experiment at the induction side but remember that if its all smooth, and straight you may not get the turbulence needed to get the mixture atomised for efficiency.
Cheers JK
oh ! im sure after air passes through the afm its disturbed enough, then with a slow right angle into the tbs and then the butterflys them selves , should mix it all up ?
still looking for a k1100 airbox top section only to get the pipes i need (already made that is ) chris from the bm shop said he would keep one for me, if one turns up .
For what it's worth, my 'European' '86 K has Gillet 3087 18121451528.
Who would have thought there were different versions?
have to congradulate a new member
halo ......(staintune)
welcome mate !
klompy (staintune )
JimK wrote:...still trying to figure out the Supertrapp exhaust literature that I got along with the bike is about.
jim i cant recall the look of your muffler ...do you have a recent pic for us ? i belive twb has a supertrap in the storage shed ...along with many nice things ...but still to see the implementation ...if you get a chance ?
Bert (2.0),
Did you ever worked on my exhaust?
Listen to that.....
Oh by the way, it was only 3⁰ and this is just steam coming out of the pipe (The bike doesn't burn oil) Very Happy
zorsts ---- old boys and young mans toys ? Frog15zorsts ---- old boys and young mans toys ? Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
sounds like its had "the treatment " bert ...nice !
crazy frog .....(unknown mod )
klompy (staintune )
Toto_jp
klompy (staintune )
toto_jp (motad)
K100 RS 1986
What's the number on your zorst CF, is it perhaps a more open one that caferacer mentioned?
Maybe US spec?
dont think so paul ...there is a cage built round the collector region ...if this was bashed through or drilled out ..it might give a simillar result
zorsts ---- old boys and young mans toys ? 2012-045
JimK
JimK
chance ?
Charlie...shall do... as soon as I find the camera.
Tis somewhere in a pile of paddling/camping gear...or ? Heh.
Owe the gathering some pics.
Am interested myself in what is on there too.
'89 k100 rs se
sidecar paul wrote:What's the number on your zorst CF, is it perhaps a more open one that caferacer mentioned?
Maybe US spec?
It really looks like an original muffler.
I am planning to first clean my workshop (put the tools back in the tool box) and will start to dismantle. I had to work in my driveway to detach the chair and it was quite cold. When the bike was finally in, people were frozzen and I had to feed them with..... cold beer. All the tools are scattered over the floor.
I will see if the exhaust was modified or if I can find a part #.
CF
Crazy Frog wrote:When the bike was finally in, people were frozzen and I had to feed them with..... cold beer. All the tools are scattered over the floor.
CF
Interesting what an over worked liver can do to raise the body temperature. 🤡
CF
Ah yes but the liver is an evil thing and must be punished as often as possible. zorsts ---- old boys and young mans toys ? 22936
Rick G wrote:Ah yes but the liver is an evil thing and must be punished as often as possible. zorsts ---- old boys and young mans toys ? 22936
Liver? Do I have one? We call that thing a sponge in Canada zorsts ---- old boys and young mans toys ? 502531
By the way, I like Saxon's avatar.... It fits them well (him and Bella).
Did you noticed that the tank's color is the same as the one on Rick G's avatar?
What's going on?
JimK
JimK
JimK wrote:jim i cant recall the look of your muffler ...do you have a recent pic
chance ?
First attempt at photo send:
zorsts ---- old boys and young mans toys ? Jpeg&filename=121116_006
'89 k100 rs se
JimK
JimK
/home/jake/Desktop/bike
'89 k100 rs se
JimK
JimK
Obvious fail.
Y'all please excuse me.
Going to go back and read more directions
S**t.
'89 k100 rs se
CommanderKewl
CommanderKewl
JimK wrote:Obvious fail.
S**t.
lol!
Maybe i should use that as my signature..
If thats ok with you...
Thats some funny stuff there.. I thought that only happens to me..
( thats why i use the supplied avatars) finding the power button is an adventure!
caferacer62
caferacer62
charlie99 wrote:dont think so paul ...there is a cage built round the collector region ...if this was bashed through or drilled out ..it might give a simillar result
Did that when i first got my K. You need a piece of solid steel bar with a sharp end or a really long screwdriver to punch the centre of the diffuser out. I have put up a pic of the diffuser out of the Zorst.
zorsts ---- old boys and young mans toys ? 2012-090
You can see where I had originally punched the centre out, you have to work around a bit but you can get a decent hole happening. Check your progress with a torch. It does make a slight difference in sound and a bit more go.
CF I know there is a family rumour that we may be of Canadian decent but I promise I've never been anywhere near your Zorst. Might pay to check up the zorst hole with a torch to see if someone has modified it. The part number is stamped on the tail section too.
I road tested Col's zorst yesterday to see how it went. Seems the goods to me,ready for you anytime Col. Went over to the BM shop for a squiz and then went and visited Beano. He has a great shed setup there complete with fridge for cold beveridges and such like(I only had a ginger beer i promise) Thanks again Beano.
On the way home down the freeway the traffic was at a standstill going the other way, and there were the boys in blue booking bike riders for lane splitting(although it could've been for riding down the outside). Don't really see what this achieves to be honest.
Bert 2.0
you could probably create that hole neatly with a holesaw ( metal cutting type ) on an extension bar .
but i wouldnt gamble on the cutout section holding inside the saw blade often ... probably best to drill it whilst in a vice and verically from the bottom so it falls cleanly out the tailpipe
oh cool bert !....we havent seen beano for ages
caferacer62
caferacer62
Good thinking Charlie, i would use a fine tooth one if you were going to do it that way. You can get extension bits that suit spade drills that work fine with hole saws. Would depend on what type of exhaust you have, wether it is the 28mm bore or 40mm bore. But its still the inner tube that needs to go completely.
Beano was dissapointed to miss the Bingara run too, he is busy doing his brake lines and steeering head bearings.
We both came to the conclusion that if it wasn't for this forum we probably wouldn't have kept our K's, its been a boon of advice and help. Cheers to you all.
Bert 2.0
caferacer62 wrote:We both came to the conclusion that if it wasn't for this forum we probably wouldn't have kept our K's, its been a boon of advice and help. Cheers to you all.
This is the best Kudos that both of you can give to all the passionate members of this forum.
Cheers,
CF
Dewey V
Dewey V
Does anyone have a photo of the exhaust system that Bassani made for the K100?
col .......(bert2 special)
welcome mate ! better post up some noises for us huh ?
klompy (staintune )
jimk ......super trapp ?
took a vid up Mount Glorious a while ago just got round to working on it .......from the turnoff to the bottom of the hill is about 15 ks ...then the fun starts ....oops the camera fell down a bit ...but its all about the noise ...enjoy !
https://youtu.be/mafM0rYObgg
My last K100 solo had a Luftmeister 4-1 system (black ceramic coated, tuned length collector) before fitting the sidecar, it wouldn't fit with the sidecar subframe so had to go. I bought it from Don Wilson Motorcycles
Sounded amazing and gave a good performance boost.
'93 K1100LT
zorsts ---- old boys and young mans toys ? K-dogs10
al ....would love to get my hands on one of those just for testing purposes ...you understand ! ...giggles
seaniis and albys are awesome ....but a "bert special " not a staintune
hope you enjoyed
must do the valve seats and rings one day and see if i can crispen up that zorst some more eh ?
walfish
walfish
You guys are blessed with lonely open roads, it'd be like hitting a lottery for us.How is you speedo calibrated mph or kms
zorsts ---- old boys and young mans toys ? Uk-log10
                            88 K 100  0033026 (gone)
                            92 K 1100 LT  6455097 (gone)
kph
the speedo sits at the same place mph or kph just the numbers are different ....some sub 40 kph corners there ...on the way up the hill
walfish
walfish
Yes some do look tight can get your elbow down though, our country roads are also used by the farmers with slow moving vehicles, one could let rip if you know the road well.
wngnutmv
wngnutmv
charlie99 wrote:took a vid up Mount Glorious a while ago just got round to working on it .......from the turnoff to the bottom of the hill is about 15 ks ...then the fun starts ....oops the camera fell down a bit ...but its all about the noise ...enjoy !
That's got a very nice sound to it. zorsts ---- old boys and young mans toys ? 112350 Where can I get a set up like that and how much will it set me back? Thanks for posting!
Mike
"Wingnut"
Nice sound Charlie, good onya!
Gerty is looking good from the pilots chair. and I see some autumn leaves on the ground there.
I like the sound but is it the video sound or is the Bert 2.0 sytem a tad more roarty?
zorsts ---- old boys and young mans toys ? Ir-log1188....May contain nuts!zorsts ---- old boys and young mans toys ? Ir-log11
K75RTP - 1994
I shall be joining the ranks of the staintune soon I scored a mufler for the K1100 a few days ago and thats what will be going back on when the rebuild is done. Instead of that leaky cracked and welded and cracked and welded and cracked and welded and cracked and welded and........................................... damn standard system not worth 2 knobs of donkey $h*t.
