1 89 K100rs occasional backfire when hot Fri May 24, 2013 12:15 pm
thal13
My recently acquired and rehabilitated k100rs has been running pretty well, but I really have no basis of comparison since this is my first experience with any K bike, so it might be that it could run even better with some additional TLC.
Since I replaced the fuel pump and got it running, it 'burbles' and occasionally backfires but only during light engine braking with a partially opened throttle. The burble actually sounds good to me, but if it's not supposed to do that then I need to rectify it. I read that the FI will cut delivery above 2000 rpm if I chop the throttle completely, but if I'm using slight engine braking with minor throttle then fuel is still being injected...right?
So what should I know? It has an aftermarket Staintune exhaust, so it might be a backpressure thing that's pretty normal, or is it likely a timing issue? I don't seem to have any flat spots in power delivery, and the bike runs incredibly well at both low speeds and prolonged highway runs. I've ridden other "modern" FI bikes with terrible snatchy on/off throttle characteristics, and I can't believe that BMW got it so right so early. Thanks for any thoughts,
thal13
thal13
