1 interesting fork modification Fri May 17, 2013 4:07 am
1986 k75, 1985 K100rt, |
The calipers can be mounted the same way as it is on the EML.sidecar paul wrote:Then it should be easy enough to make some caliper mounting plates. Sorting the wheel axle mounts is rather more tricky though.
Exactly my feelings,Crazy Frog wrote:
I already have a leading fork, but designing something to modify the original fork interest me.
CF
More or less, but sidecar blokes do go to some weird pages.K75cster wrote:Just so I get this right, you are talking of using the left leg in the right and right in the left that is pull em both out and turn em over and put em in then fabricate the fork extension. if that is right and you add the callipar mounts to the fork extension then all that is needed is for longer brake tubes fron the flexible hose to the new calipar location, am I on the same page as you blokes yet????
K100-forum.com » Technical, repair and troubleshooting » Everything about adding a chair(sidecar) on a K Bike..... » interesting fork modification
Similar topics
