1 Final drive thrust bush and nut Sat Jun 22, 2013 3:16 am
G'day All
I just removed the final drive to grease the drive shaft splines, and to my surprise as I was pulling the final drive from the swing arm the final drive thrust bush and nut fell out on the floor with a small amount of diff oil. After close inspection there appears to be no physical problems with the final drive unit. No bearing movement or back lash of any sort even the seal appears to be in great shape.
Has anyone else experienced this issue? And what would be the likely cause. On inspection the threads appear to have no lock tight residue on them. So my plan was to put it back together with lock tight on the thread. As this nut will need to be put back on with a tube spanner my question is how tight does it have to be? This bike has travelled a mere 24.000 km and I would be very surprised if the final drive has ever been off before. Any other ideas would be appreciated.
Smithy
Smithy
