1 Tail Light Fri May 24, 2013 6:49 am
Rickmeister
Tail light failed on the Nerrandera trip. No alarm on the instrument panel. Checked the lamp, didn't work when 12V was applied. Bought replacement lamp. No joy. Removed lamp, measured open circuit volts at the lamp holder. 5½V. Perused Bert's diagram of the bulb monitoring unit. The first item after the light switch is what? Fuse?. Anyway, my understanding is that when the light is switched on, the current drawn by the tail light operates a reed relay which switches an earth to the transistor doo-dad in the dotted box. Being chronically technophobic these days, I don't really understand what happens inside the dotted box.
Any suggestions as to where the other 7 Volts are being lost?
