This is her naked...the guy before me did the MODs so far...I'll do the rest once she's running smooth.
So yesterday I installed the new NAPA 3032 fuel filter, New NGK DR7EA spark plugs left at the gap they came with (no screw on bobbins...can they be removed from the old XR5DC?) as well as fresh oil and K&N KN163 oil filter.
My plugs looked pretty black from the previous owner and I'm told that by the looks of them fuel injectors might be the culprit for my sever lack of power.
After the aforementioned maintenance was done, bike fires right up and idles way stronger.
But when I twist the throttle, there is a 1 sec "choking out delay" before she responds with a throttle increase. Other than the delay, she seems to run ok on flat ground.
She BARELY could go 5 MPH up a decent grade hill (throttle wide open, little or no response...unless I popped the clutch, then I get a jolt of power which would subside as the momentum dwindled....like a solid lady, no problems going down.
There are a few other things that raised my attention. The fuel pump is continuously making a high pitch "whistle" that can be heard with the engine running...the tank had about 1/3 tank of gas.
Does one of the gas lines coming out of the fuel pump remain unattached and just remain sitting in the bottom of the tank to syphon the gas?
I'm going to check the air filter now, and probably flush the radiator and change the coolant while I research the next move.
Next moves seem like:
1 Fuel Pump
2 Fuel Pump Regulator
3 Fuel injectors
Thoughts??javascript:emoticonp('
