1 Schuberth C3 Pro Mon Feb 18, 2013 6:51 pm
twincarb
Well I was in the market for a new helmet so decided to go looking for something that would suit what I wanted. I decided that I wanted a flip up helmet and not spend only £40 which you can pay for the budget range.
I pretty much had my eyes set on another Shoei my last one has served me well for over 5 years so past it's shelf life. I went to the local Hein Gerieke shop which since there restructure is 150 miles away and a 3 hour ride. I thought that it would give me a good chance to bed the helmet in! That it did as I shall explain.
First a couple of photo's:
As you can see from the photo's I have got the optional inbuilt headset which is bluetooth compatible capable of connecting to 3 other G4 type headsets or a bluetooth device and 2 G4 headsets. It also has a built in FM radio and you can connect a media device via a headset jack.
First up what problems have I had with the helmet... Well when I bought it from the shop they helpfully fitted the headset for me this meant removing the original collar and installing the replacement one. What they did was to install the optional pads behind the speakers designed to move the speakers closer to the ears... Thats fine if you have a head to fit the smaller part of the size spectrum! After 15 miles I my ears were hurting from a lack of blood circulation. Not a problem I thought I can hack this I just need to allow the helmet to soften with use. 30 mins further riding I found a layby to pull in and gave myself 5 mins break from riding and wearing it. This carried on for 100 miles of riding stopping every 30 mins. I hasten to add that it was late in the day and I left the shop shortly before closing!
After 100 miles I had enough and decided I was going to remove the headset part and fit the standard collar. That was when I noticed the 2 offending pads! I took the pads out and carried on. The last 50 miles was a lot better and I didnt need to take another break although the damage was done. It took a couple of days for my ears to recover!
Having now worn the helmet for a couple of weeks and having used it on both the K100LT with its massive fairing and also on my Thundercat I can honestly say that the helmet is great. The padding has stretched with wearing it so is now comfortable, it needs to be as I commute to work just over an hour each way. It's easy to put on and take off just so long as the ears don't fold over!
I wear earplugs when riding and the noise level is very low I would say comparable to my sold helmet with ear plugs removed the noise levels are lower than my Shoei which is saying something. I was always concerned that a flip lid would be noisier.
The buckle system it uses is a very simple ratchet device which locks into the position. They provide a chin guard which I have binned as I find it pushes the buckle back into my throat! not conducive to a good ride in my books.
Riding on the K there isn't a lot of air that gets past the visor so around town there is a need to open the visor slightly but when moving along with the top air vent open ajar it allows plenty of air to circulate keeping everything clear. That includes my glasses. As a glasses wearer its a pain to have to swap over to sun glasses when the sun comes out. Not a problem with this helmet it has a built in sun visor which drops down with the slide of a lever. Even this early in the year I have used it loads again no fogging and is superb.
Riding on the Thundercat I found there is no need for the top vent to be open just the one under the visor this allows a decent amount of cool air to flow around the helmet. Whats more at high speeds there is no wind buffeting at all due to a couple of aerofoils at the front and a slight wedge at the back. I didn't think they would make any difference but they make a world of difference!
With the headset listening to the radio is a dream the volume isn't deafening most people can't believe I have a clear volume when I take the helmet off and then remove my ear plugs! It has built in VOX which works very well and doesn't leave you noticing to much the change in volume as you change speed. Using it as a bluetooth headset with the phone is also crystal clear. I phoned the shop by mistake the day after purchase as I was riding and they couldn't believe that I was riding the bike with the phone quality.
Conclusion:
An expensive helmet with an expensive headset built in, but considering I ride the bike most days and high mileages I think it is worth it. When I come to replace this helmet it's probably going to be hard to beat it for comfort and noise levels.
Any questions please feel free to ask
Conclusion:
BMW K100LT 1988
Yamaha Thundercat
