1 spoke to soon Sun Oct 11, 2009 11:31 am
yankeeone
Hi, every thing was great till... pushed starter small click .. nothing tried to jump, all lights went out on dash, switched bat, same switched starter same , checked grounds under tank when I remove them the dash lights come on. replace them they go out, the clock goes out when you switch the kill switch ,so no lights or any thing , the saver relay makes some noise but what! so I get nothing when I turn on the key, unless I pull the grounds, then just the dash lights, help. also the alt light took a a bit of revving to get it to go out that morning ,could the alt. be the problem.
Brian
Brian
