1Back to top Go down   k100 modifying Empty k100 modifying Sun Apr 28, 2013 10:13 pm
rocket23
rocket23
I won this bike on ebay.
k100 modifying 7736097990_76202926e2
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, martini in the other, body thoroughly used up, totally worn out, and screaming,'WOO HOO! What a ride!'"
2Back to top Go down   k100 modifying Empty Re: k100 modifying Sun Apr 28, 2013 10:16 pm
rocket23
rocket23
After I brought it home ,it had electrical problems......so the tear down began.
k100 modifying 7245274592_7557a17c5b
This was the culprit.....
k100 modifying 7249943216_54a362b177
seems some field mice had an alll night buffet!
3Back to top Go down   k100 modifying Empty Re: k100 modifying Sun Apr 28, 2013 10:19 pm
rocket23
rocket23
Next was the rear splines!
k100 modifying 7262329366_9773c6f4ab
k100 modifying 7262330230_c65e2a30a8
k100 modifying 7262330858_d79d169365
i used never ceaze on the mid and rear splines.....(it contains moly-lube) and the splines are doing fine.
4Back to top Go down   k100 modifying Empty Re: k100 modifying Sun Apr 28, 2013 10:22 pm
rocket23
rocket23
Next was the triple tree, the farings and windscreen were shot ( 6 years falling over in a barn), So here comes the modifying!
k100 modifying 7180708551_65b57581b5
k100 modifying 7365935850_d9d2913411
k100 modifying 7365936184_c02084e474
5Back to top Go down   k100 modifying Empty Re: k100 modifying Sun Apr 28, 2013 10:24 pm
rocket23
rocket23
course the seat took a beating as well!, I had it refurbished with naugahide,had it sewn up for 90 bucks!
k100 modifying 7383735292_1a5cf0687d
6Back to top Go down   k100 modifying Empty Re: k100 modifying Sun Apr 28, 2013 10:26 pm
rocket23
rocket23
Then I fitted a rifle faring and this is how she came out!
k100 modifying 7519970660_18bd5037de
k100 modifying 7519972866_1e4af6cce0
7Back to top Go down   k100 modifying Empty Re: k100 modifying Sun Apr 28, 2013 10:27 pm
rocket23
rocket23
Needless to say the progressive shock was spent.....and a little tall for me (14 inches), So I found one shorter and much nicer!
k100 modifying 8169605356_6c8a581e39
8Back to top Go down   k100 modifying Empty Re: k100 modifying Sun Apr 28, 2013 10:29 pm
rocket23 wrote: i used never ceaze on the mid and rear splines.....(it contains moly-lube) and the splines are doing fine.
Never-seeze might not have a sufficient quantity of molybdenum to serve as spline lube. The proper lube will have 60% molybdenum content. Check the MDS for the stuff you've used to see whether it meets this spec.
9Back to top Go down   k100 modifying Empty Re: k100 modifying Sun Apr 28, 2013 10:40 pm
rocket23
rocket23
Your correct, it doesn't. But the miles or lack there of that I put on her makes it a quick fix. I plan on another tear down in the fall with bmw moly Plus a look at the front spline, which is still riding stock, but rarely wears out thankfully. For a barn find I thought I was gonna be trashing the bike especially with the electrical issue's. But I took my time and spent 3 month's doing it on a shoestring budget. This is the second season and I only run 900 hundred miles a year usually on a bike......last year was a miniscule 189 miles. I put on over 400 since the april start up.
