1Back to top Go down   battery mount Empty battery mount Thu Aug 27, 2009 3:27 pm
yankeeone
Hi, just got new (85) motor, trans, rear drive, the trans. only has two rubber mounts for the battery plate , the other two are steel plugs. Is this normal for the 85?
edit------ Think first! the steel plugs are whats left of the mounts got them out with cold chisel!
Brian
2Back to top Go down   battery mount Empty Re: battery mount Thu Aug 27, 2009 4:25 pm
The tray is mounted on 4 rubber mounts.
The BMW # is: 61 21 1 233 028
Bert
battery mount Frog15battery mount Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
3Back to top Go down   battery mount Empty Re: battery mount Fri Aug 28, 2009 10:38 pm
Cablebeacher
Hi Brian
When I did my rebuild two of the rubber mounts were just sitting on holes in the transmission. They had either rusted (Aluminium?) or had worn through vibration or heavy handidness. I rethreaded the holes using a (easily?) available Helicoil.
In a big box of spares I may have one or two of these mounts. I will look today. Otherwise they sometimes come up on ebay...
I am not sure of the price of a new replacement as recommended by Bert...
Regards
Mal
4Back to top Go down   battery mount Empty Re: battery mount Sat Aug 29, 2009 12:29 pm
yankeeone
Thanks , I have some rubber mounts, what I saw and reacted to with out thinking , were the the forward mounts , the rubber was gone and just the steel base were in the tran. so I thought there were no mounts, but when I gave it a few seconds thought, was able to get them out with a small cold chisel. The new motor that just recived from Fla. looks good, the splines in the rear drive look brand new, and I will clean it up and be on the road. I will keep you posted.
Brian
