1Back to top Go down   Bike wouldn't start today Empty Bike wouldn't start today Sun Jul 19, 2009 9:59 am
Hi all,
My bike failed to start today! Swine flu??
It was running last week. Then, today I tried to start it and the engine turned over and nearly started. It even ran for a few seconds at 5oo rpm but then stopped. It kept doing this, when I connected the battery to another source.
Any thoughts? Where to look first? The fuses are all fine. Will do some inspections tomorrow.
Cheers,
Neal
2Back to top Go down   Bike wouldn't start today Empty Re: Bike wouldn't start today Sun Jul 19, 2009 11:06 am
Oh no! not another roy's problem Embarassed
If the bike ran at 500rpm, it shouldn't be a big problem.
Remove your spark plugs, dry them with a propane torch.
Run the bike for a few seconds without the spark plugs (to clean the cylinders of any excess of fuel).
Put the spark plugs back on an try again.
If the bike doesn't start, report to us on the state of the plugs (wet tor dry).
Bert
3Back to top Go down   Bike wouldn't start today Empty latest... Mon Jul 20, 2009 3:05 am
Hi Bert,
Thanks for getting back to me.
I checked the plugs - they were wet. I dried them off and the bike did the same thing - tried to fire up and ran for 3-4 seconds at 500 rpm a couple of times.
I took the engine rocker cover off to check the cams are working. All looked fine so no seizure of valves (?).
Could there be a seizure in the engine?
There is a spark - only checked cylinder 1 for the moment though.
Neal
4Back to top Go down   Bike wouldn't start today Empty Re: Bike wouldn't start today Mon Jul 20, 2009 10:25 am
At this point, the diagnostic is very difficult to do.
What I would do is start with the easiest: put a new (or known to be working) set of spark plugs on the engine.
5Back to top Go down   Bike wouldn't start today Empty Re: Bike wouldn't start today Tue Jul 21, 2009 4:44 pm
Hi Neal,
Sorry, I missed your post. Way out left field has the bike got a partial blockage on the air inlet? I recall Bert telling us about pests (squirrels I think) filling up his inlet tract with nuts. Also think is the fuel pump putting put full flow, Easy check to take the supply line off and try to see if it pumps fuel out at a good rate. If the pump has partly siezed it would strangle the flow.
Jeremy
6Back to top Go down   Bike wouldn't start today Empty Re: Bike wouldn't start today Sun Jul 26, 2009 5:08 am
Hi Jeremy,
Thanks for your reply - been away for a bit so only just logged in.
I had a good look at the bike and this is what I have seen:
Was able to turn the engine with an allen key - so not seized. had engine covers off and could see everything moving. Good compression it seems. Haven't done a proper test yet.
Starter motor seems to be working - when I connected the battery leads to another battery I could hear the starter motor working when I pressed the starter button.
Fuel getting into cylinders
Need to put 4 new plugs in
Need to check air as you suggest
Engine still almost started but cuts out after a short low rev burst on first push of starter button
What does it all mean? It's beyond my humble skills for the moment.
What avenues should I explore next?
Cheers, Neal
7Back to top Go down   Bike wouldn't start today Empty Re: Bike wouldn't start today Sun Jul 26, 2009 5:28 am
reg_K100RS
As it was running fine when you parked it up and now doesnt want play
My guess is its something electrical like a poor connection
Try opening/cleaning all related conectors especially the ECU, TPS etc and trying again.
I had an 85RT that was unwilling to go before I opened and
cleaned all the connections and many of them were oxidised
Some Servisol Electrolube (from Maplins etc) is handy here
Good luck with it
8Back to top Go down   Bike wouldn't start today Empty K100 won't start Sun Jul 26, 2009 6:44 am
Thanks for that - will give that a go.
Cheers!
9Back to top Go down   Bike wouldn't start today Empty Re: Bike wouldn't start today Sun Jul 26, 2009 7:08 am
Hi Neal,
My favourite contact cleaner and preserver is Deoxit, what I suspect is happening is there is a poor connection. Clean the connections to the airflow sensor, both temperature sensors and the throttle position switch plus check, clean and re-seat the plug to the engine management system. The other thing would be very low flow from the fuel pump. Clean the connector to the fuel pump which is in the cable which comes from the tank.
10Back to top Go down   Bike wouldn't start today Empty Re: Bike wouldn't start today Sun Jul 26, 2009 9:23 am
Thanks for that - appreciate your replies, guys!!
11Back to top Go down   Bike wouldn't start today Empty Re: Bike wouldn't start today Sun Jul 26, 2009 9:25 am
the good thing is I have had a more thorough look at stuff - tested thermostat (wife didn't mind it sitting there in a saucepan!) and worked fine. Will replace shocks in alternator too. Service water/oil pump. Hopefully she'll (not the wife) be running even better...
12Back to top Go down   Bike wouldn't start today Empty Re: Bike wouldn't start today Sun Jul 26, 2009 4:04 pm
roys
Hi Neal,
If not too much trouble can you explain (photos?) "Was able to turn the engine with an allen key.."? It sounds like something one should know how to do. I am trying to learn as much as I can and perhaps there are other who can also benefit from learning this - so I hope this is not too much to ask.
Also, do you perhaps have photos of "engine covers off"?
Thank you,
Roy
13Back to top Go down   Bike wouldn't start today Empty Re: Bike wouldn't start today Sun Jul 26, 2009 6:25 pm
Will post some photos at earliest opportunity. Good idea!
Just above the oil/waterpump there is a T shaped piece. Under this is the Hall sensor (electronic device serving purpose of points on an older style engine) and in the middle of that is an allen key shaped socket. You can turn the engine with a key here (anticlockwise I believe is important to note).
14Back to top Go down   Bike wouldn't start today Empty Re: Bike wouldn't start today Sun Jul 26, 2009 7:28 pm
roys
tnx. hall sensor i replaced once so at least Iknow where this is...
15Back to top Go down   Bike wouldn't start today Empty Re: Bike wouldn't start today Wed Aug 12, 2009 6:32 am
Hi all,
so far I have cleaned all contacts and checked over the fuel tank innards. Found a hose that was loose - wonder if I had a drop in pressure because of that.
I have been checking over the oil/water pump too - just a bit of routine cleaning adn checking. The seals seem OK.
I'll be putting her back together soon adn will see if she is more willing to start then...
Am trying to post some pics...
[img][/img]
