1Back to top Go down   A Definative Guide to Tools Empty A Definative Guide to Tools Sun Mar 31, 2013 8:28 pm
Originally posted by Tim on the UK BMW site in their jokes section, and copied therefrom, some I laughed until tears came because like most humour there is a huge amount of truth in there.
HAMMER: Originally employed as a weapon of war,
the hammer nowadays is used as a kind of divining rod to locate
expensive parts not far from the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly well
on boxes containing seats and motorcycle jackets.
ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets in
their holes until you die of old age, but it also works great for
drilling mounting holes in mudguards just above the brake line that goes
to the rear wheel.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more
dismal your future becomes.
VICE-GRIPS: Used to round off bolt heads. If nothing else is available,
They can also be used to transfer intense welding heat to the palm of
your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
objects in your garage on fire. Also handy for igniting the grease
inside a brake drum you're trying to get the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and
motorcycles, they are now used mainly for impersonating that 9/16 or
1/2" socket you've been searching for the last 15 minutes.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest and
flings your beer across the room, splattering it against that freshly
painted part you were drying.
WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere
under the workbench with the speed of light. Also removes fingerprint
whorls and hard-earned guitar calluses in about the time it takes you to
say, "Ouch...."
HYDRAULIC FLOOR JACK: Used for lowering a motorcycle to the ground after
you have installed your new front disk brake setup, trapping the jack
handle firmly under the front mudguard.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a motorcycle upward off a hydraulic jack.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbour to see if he has another hydraulic floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for
spreading mayonnaise; used mainly for getting dog-doo off your boot.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit.
TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup.
TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile
strength of ground straps and brake lines you may have forgotten to
disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool
that inexplicably has an accurately machined screwdriver tip on the end
without the handle.
BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulphuric acid
from a car battery to the inside of your toolbox after determining that
your battery is dead as a doornail, just as you thought.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The mechanic's own tanning booth. Sometimes called a drop
light, it is a good source of vitamin D, "the sunshine vitamin," which
is not otherwise found under motorcycles at night. Health benefits
aside, it's main purpose is to consume 40-watt light bulbs at about the
same rate that 105-mm howitzer shells might be used during, say, the
first few hours of The Battle of the Bulge. More often dark than light,
its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style
paper-and-tin oil cans and splash oil on your shirt; can also be used,
as The name implies, to round off Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning
power plant 200 miles away and transforms it into compressed air that
travels by hose to a Chicago Pneumatic impact wrench that grips rusty
bolts last tightened 40 years ago by someone in Sindelfingen, and rounds
them off.
PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 pence part.
HOSE CUTTER: A tool used to cut hoses 1/2 inch too short.
_________________
Regards Tim,
"Good health is merely the slowest rate at which one can die."
2Back to top Go down   A Definative Guide to Tools Empty Re: A Definative Guide to Tools Sun Mar 31, 2013 8:59 pm
marvelous
thanks kbike
3Back to top Go down   A Definative Guide to Tools Empty Re: A Definative Guide to Tools Sun Mar 31, 2013 9:04 pm
krambo
krambo
Wonderful and so true - I'm going to have to steal this and repost it elsewhere Wink
"Aut viam inveniam aut faciam." A Definative Guide to Tools Uk-bmw12
http://www.its-personal.net
