1 Using a Gas tank sealer on k100 tank? Tue Apr 02, 2013 4:43 pm
excorcist
Hi, I have a k100 tank that i started to sand and like many other tanks, it has some pinholes around the bottom area next to the weld seam. I patched from the outside with a thin layer of jb weld, now I want to seal it from the inside. I was going to use a Motorcycle gas tank sealer kit, it comes with a cleaner, a prepper, and the actual sealant, Im wondering If I will have any trouble with any of the moving parts, Or how i Will be able to block off the two hoses on the left side of tank ( one is the fuel outlet, the other i believe is some sort of vacuum line?) So they do not get sealed shut. I can remove any parts that I need to,,, i was hoping someone has done this in the past, or at leat can provide some suggestions.
Here is the product I want to use:
http://www.summitracing.com/parts/kco-52000
