1Back to top Go down   Poor gasoline causes missing?? Empty Poor gasoline causes missing?? Fri May 01, 2009 11:24 pm
scottiesharpe
scottiesharpe
One think I love about the brick is the rock solid idle. It's cool to hear that thing puttering away. So I was a little bothered by the fact that my K would not want to idle after a long drive. I recently put 500 miles on on a drive to Alpine Lake CA and the temp ranged from 101F to 37F. In the heat, the bike would stall at lights if I didn't give it throttle. When the temp dropped, it seemed to idle fine.
What made matters worse was after I returned home, I filled up with fuel (91 Chevron, I think) and for the next 150 miles, the bike ran like crap. Would not idle at all, and would sputter and miss at low RPM. Drop in power, too.
Felt like a defective coil.
Yesterday, I filled it up with Chevron 91 (from a different station) and it seems to run better. Well at least I can drive it without "nursing" the throttle at lights to keep it running.
I wonder if I got a batch of bad gas?
I wonder if my heat-soak idle problem is still there?
I'm going on a 500 mile ride next Sunday. I guess I'll find out.
Anybody carry a spare hall effect sensor, coil, etc in their tail cone for such problems?
Scottie
2Back to top Go down   Poor gasoline causes missing?? Empty Re: Poor gasoline causes missing?? Fri May 01, 2009 11:56 pm
phil_mars
Hi Scottie,
You have to wonder how accurate these octane ratings are and I bet if measured from different stations they would all be different. Recommended octane rating for mine is 98 so that's what I use although not that easy to find plus a lead additive which is also supposedly an octane booster.
Even my lawnmower will not run smoothly on the 91 we have here so it and my wife's car run on 95 even though they are supposedly capable of running on lower.
Your problem certainly seems fuel related so I guess your ride on Sunday will tell you one way or the other.
Phil
3Back to top Go down   Poor gasoline causes missing?? Empty Re: Poor gasoline causes missing?? Sat May 02, 2009 12:01 am
Hi Scottie,
Why not fill up with higher octane 95 or 98 to see what the effect is?
It cannot harm the bike to try that.
4Back to top Go down   Poor gasoline causes missing?? Empty Re: Poor gasoline causes missing?? Sat May 02, 2009 1:36 am
Hi Scottie,
Have you tried a plug swap sometimes a bad plug can cause the symptoms you describe. Known good spark plugs is worth doing, when did you last change the plugs?
5Back to top Go down   Poor gasoline causes missing?? Empty Re: Poor gasoline causes missing?? Sat May 02, 2009 11:12 am
3 weeks ago, my K100 got exactly the same problem as the one that you described.
I was also thinking about ignition, bad gas or plugged fuel filter, but found a very different problem....
Let me explain:
I went for a ride and the bike was running fine. I stopped for 5 minutes at a store and when I restarted the bike, it wouldn't idle.
The bike was running great as soon as I throttled over 2000rpm. I went back home and stored the bike in the shed for the night.
Next morning, I decided to troubleshoot the problem.
First, I started the bike, and surprise, the idle was perfect. I let the bike warmed up and then it started to crap up.
I swapped the spark plugs, restarted but it was still not idling.
I started to check the electric connections, spark plug wires....... Then when trying to start again the battery went dead!
The battery is only a year old and always on battery tender during the winter. Exclamation Question
(my next step would have been to check the water temperature sensor)
I took the battery of the K75 installed it on the K100, started the bike and could not replicate the problem. After charging the original battery for only 5 minutes, I tried it and it was working again.
I then checked the alternator on the K100 and everything looked good. What I found, is that the alternator doesn't produce power if the engine is running under 1200rpm.
The bike idle between 850 to 1000rpm and relies only on the battery to provide power to all the electronic and lighting system.
My original battery has certainly a bad cell intermittently shorting out and the voltage gets too low to run everything. This may occurs when the engine is running and the vibration of the engine shakes the cells of the battery. Could it be a loose cell ?????
Why the problem showed up only when the bike was warm is a mystery.
Since swapping the battery I put about 700kms on the bike and did not experienced anymore idling problems.
Let us know we you find on your bike.
Bert
6Back to top Go down   Poor gasoline causes missing?? Empty Re: Poor gasoline causes missing?? Sat May 02, 2009 10:16 pm
scottiesharpe
scottiesharpe
Problem seems to be solved. I did swap plugs and that seems to have solved my problem. I may have had bad gas too?
I will also check the battery electrolyte levels (it's a BMW battery) not sure of its age. It was on the bike when I bought it.
7Back to top Go down   Poor gasoline causes missing?? Empty Re: Poor gasoline causes missing?? Sat Aug 29, 2009 12:18 am
scottiesharpe
scottiesharpe
Update: I thought would update this topic. The problem was not my plugs or wires, or hall sensor. The problem was defective coils. I have never had a defective coil on a BMW before, so I was surprised. Both coils were bad. Replaced both coils with parts from a parts bike, and my bike runs like new.
8Back to top Go down   Poor gasoline causes missing?? Empty Re: Poor gasoline causes missing?? Sat Aug 29, 2009 4:48 pm
Hi Scottie,
Good news, now as a bit of data for the test schedule when the next person has the same problem, can I suggest you post the results here of the coil tests so this thread provides an answer for the future if someone follows this thread.
9Back to top Go down   Poor gasoline causes missing?? Empty Re: Poor gasoline causes missing?? Sun Aug 30, 2009 4:51 pm
scottiesharpe
scottiesharpe
Yeah, good idea. Actually I had started two posts because I wasn't sure if I had an electrical problem or an engine problem.
The other post has the solution and coil measurements.
http://k100rt.aforumfree.com/engine-and-transmission-f10/poor-idling-and-low-rpm-power-returns-t406.htm
10Back to top Go down   Poor gasoline causes missing?? Empty Re: Poor gasoline causes missing?? Sun Aug 30, 2009 6:05 pm
I just found my spare coil and measured it. I get 12.55 kΩ between 4a and 4b, and 2.6 Ω on the primary (between 1 and 15)
Poor gasoline causes missing?? Frog15Poor gasoline causes missing?? Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
