1 Fan trouble shooting Mon Nov 19, 2012 5:42 pm
MT350Explorer
Hi Guys,
The fan does not appear to be cutting in when it should. In the pic below is the temp gauge. In normal motion the needle is straight up so I assume it is probably working OK. If i leave the bike idling the temp rises. It has got as far as where I have marked the gauge in yellow before I turned the engine off or went for a ride to cool it down - for fear of damaging the engine. I am assuming the fan should have kicked in before this?
I have taken off the fairing and accessed the connection to the temp sensor beneath the bottom of the rad; it snicks into place and seems to connect OK. I cleaned it with Deoxit and left well alone. Also cleaned the connection under the tank.
I've just put 12 volts directly through the fan at the connection under the tank - and it works! Great, no new fan needed. The fuse is also fine - cleaned and wiggled all the fuses with Deoxit.
Advice on my next step please. Remove the temp sensor?
Thanks as always
Dave
Thanks as always
Dave
1991 K100 RS 16 valve
