1Back to top Go down   Fuel pump Question Empty Fuel pump Question Thu Feb 14, 2013 6:06 pm
2slow
2slow
I have a 85 k100 I just bought a 91 k100 when I turn the key on on the 91 I hear the fuel pump run on the 85 when I turn the key on I don't hear it run however it starts and runs fine (alittle harder starting than the 91) question is are they different systems or should I hear the pump on the 85 if so any ideas what might be wrong thanks
2Back to top Go down   Fuel pump Question Empty Re: Fuel pump Question Thu Feb 14, 2013 6:19 pm
Ned
Ned
On my 86K100rs the pump kicks in when the starter button is presses. I know that because I have a fuel pressure gauge between the tank and the fuel rail.
BTW the pressure builds up to 36psi within a second or two.
Ned
3Back to top Go down   Fuel pump Question Empty Re: Fuel pump Question Thu Feb 14, 2013 7:00 pm
On a Jetronic euqipped bike (2V) the fuel pump builds up the pressure when you
hit the starter button.
On a Motronic euqipped bike (4V) the fuel pump builds up the pressure when the
ignition is switched on.
4Back to top Go down   Fuel pump Question Empty Re: Fuel pump Question Fri Feb 15, 2013 3:56 am
2slow
2slow
that's what I needed to know thanks
5Back to top Go down   Fuel pump Question Empty Re: Fuel pump Question Fri Feb 22, 2013 6:10 pm
Themason
Themason
They are completely different fuel pumps too, though you can backfit the later pump to the earlier bike and have done so on one of my K100s.
1986 R-80G/S w/1000 cc engine
