1Back to top Go down   K1100 clutch cable Empty K1100 clutch cable Sun Feb 10, 2013 4:13 am
Is any one bidding on this cable for a K1100?
http://www.ebay.com.au/itm/BMW-Motorcycle-k75-k100-k1100-Clutch-Cable-/111010952271?pt=AU_Motorcycle_Parts_Accessories&hash=item19d8c4b44f&_uhb=1#ht_500wt_1414
If not, can any one tell me if it will also fit the 100LT, and I may throw in a bid to keep a spare.
I have replaced 2 on the RT in 7 years, but none yet on the LT during the past 4 years of use(touch wood).So far so good.
K1100 clutch cable 10_x_110
2Back to top Go down   K1100 clutch cable Empty Re: K1100 clutch cable Sun Feb 10, 2013 4:20 am
If it is a K1100LT then it will fit a K100LT/RT but RS cables are different length to LT
3Back to top Go down   K1100 clutch cable Empty Re: K1100 clutch cable Sun Feb 10, 2013 4:34 am
Yes it will fit...but if the bids go over $30AU, it'll be cheaper to get it from Moto-bins in the UK. Add a bit for postage.
Or $50AU from Munich Motorcycles in Perth.
...and I know that you know to make sure you grease the nipple (snort, giggle) at the handlebar and the one on the clutch arm near the rear wheel.
