1 New member from Paynesville, Victoria Mon Jan 07, 2013 7:55 am
Vic21
I finally brought my first BMW a 1984 K100 just before Christmas as a project, she had been sitting in a shed on a farm for about 10 years, and looked like it too, loaded her onto the trailer, and on the way home stopped at the car wash, after quite a few coins I was amazed at how good she looked, then there was the down side, getting a bike that hadn't been moved in ten years back on the road, so that's why I joined the forum, the information I have gleaned from the forum has been very helpful and knowledgeable, I pulled the battery out topped it up and put it on the charger and It actually charge up and holds a charge not bad for a ten year + old battery, then I drained the fuel out, tank is as clean as a whistle, tested the fuel pump no noise so i took it out, filled it full of crc 5.56 and it worked, so now only a oil, coolant, brake fluid, change, new plugs, new fuel pump collar, and pray the injectors work and i'm ready to try and start her, as soon as I find a hill, the starter sprag is not working either, I hope it frees up with new oil and a run, and that's pretty much it. All the work I've done has been from what I've found on this forum thank you. Vic
