1Back to top Go down   Blonde Moment.. Empty Blonde Moment.. Fri Jan 04, 2013 4:03 am
Albyalbatross1
Albyalbatross1
Had to share this one too funny not too.. Check THIS out. Very Happy
2Back to top Go down   Blonde Moment.. Empty Re: Blonde Moment.. Fri Jan 04, 2013 4:12 am
Whats heavier;
1. A tonne of lead or
2. A tonne of feathers?
KKlompy Blonde Moment.. 2854237993
Blonde Moment.. Au-log10
3Back to top Go down   Blonde Moment.. Empty Re: Blonde Moment.. Fri Jan 04, 2013 4:44 am
Interestingly I was asked for the 11 Plus exam a lot of years ago if you drop a pound of lead and a pound of feathers off the top of a tall building which one reaches the ground first. I answered the pound of lead and was marked wrong because said the examiner they both reach the ground at the same time because they weigh the same. Now that betrays astounding lack of knowledge of the physics of falling objects because Dalton's famous guinea and feather experiment in an evacuated glass tube shows they both fall at the same rate regardless of weight but the density of lead is so much greater the lead presents less wind resistance than the feathers so the effect of the drag would make the lead reach the ground faster. If the feathers were not constrained into a single block they could take some minutes to reach the ground given the up-currents that flow up the face of many tall buildings.
4Back to top Go down   Blonde Moment.. Empty Re: Blonde Moment.. Fri Jan 04, 2013 4:48 am
If the weights were both contained in identical boxes they would both hit at the same time...but a tonne of feathers would represent a large area for wind resistance (sans box)....but surprisingly there are some who think 1 ton of lead is heavier than the same weight of feathers...lol
5Back to top Go down   Blonde Moment.. Empty Re: Blonde Moment.. Fri Jan 04, 2013 5:47 am
Klompy the grey brick wrote:If the weights were both contained in identical boxes they would both hit at the same time...but a tonne of feathers would represent a large area for wind resistance (sans box)....but surprisingly there are some who think 1 ton of lead is heavier than the same weight of feathers...lol
You got it wrong!
The lead travels at 80MPH and it will take 58min to reach the ground if the building is 1 mile high.
The feathers travel at 40MPH, and considering that the blond can run at 8MPH, it will take approximately 3 min to reach the ground.
Here is the formula used:
Blonde Moment.. Math-f10
The blond was right and she won a new clock
Blonde Moment.. Math-c10
Blonde Moment.. Frog15Blonde Moment.. Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
6Back to top Go down   Blonde Moment.. Empty Re: Blonde Moment.. Fri Jan 04, 2013 6:02 am
she will never get anywhere on time now!!!!!
7Back to top Go down   Blonde Moment.. Empty Re: Blonde Moment.. Fri Jan 04, 2013 6:04 am
OK smarty pants what is heavier one ounce of gold or one ounce of lead.
8Back to top Go down   Blonde Moment.. Empty Re: Blonde Moment.. Fri Jan 04, 2013 6:08 am
Rick G wrote:OK smarty pants what is heavier one ounce of gold or one ounce of lead.
The feathers? Blonde Moment.. 652573
9Back to top Go down   Blonde Moment.. Empty Re: Blonde Moment.. Fri Jan 04, 2013 6:11 am
similar density....although I would have to ask.........how many carats?
10Back to top Go down   Blonde Moment.. Empty Re: Blonde Moment.. Fri Jan 04, 2013 6:19 am
Pure Gold
11Back to top Go down   Blonde Moment.. Empty Re: Blonde Moment.. Fri Jan 04, 2013 6:30 am
troy pound?
480 grains for the gold
437½ grains for the lead
Blonde Moment.. 214585 Blonde Moment.. 261959
I won This Newfie digital clock
12Back to top Go down   Blonde Moment.. Empty Re: Blonde Moment.. Fri Jan 04, 2013 6:35 am
13Back to top Go down   Blonde Moment.. Empty Re: Blonde Moment.. Fri Jan 04, 2013 6:40 am
Why is a duck?
Because one of it's legs are both the same. cheers Big thumb lol! Laughing
14Back to top Go down   Blonde Moment.. Empty Re: Blonde Moment.. Fri Jan 04, 2013 6:46 am
rossco wrote:Why is a duck?
Because one of it's legs are both the same. cheers Blonde Moment.. 1994076483 lol! Laughing
Gees Rossco you really need that holiday Blonde Moment.. 610153
15Back to top Go down   Blonde Moment.. Empty Re: Blonde Moment.. Fri Jan 04, 2013 6:46 am
What would you rather do or go fishing
16Back to top Go down   Blonde Moment.. Empty Re: Blonde Moment.. Fri Jan 04, 2013 6:48 am
Why do mice when they spin?
Because the higher they fly, the much.
or if you really want to think about it....
Because the higher they fly, the fewer
17Back to top Go down   Blonde Moment.. Empty Re: Blonde Moment.. Fri Jan 04, 2013 7:25 am
That makes absolutely no.................................................Very Happy
18Back to top Go down   Blonde Moment.. Empty 1/2 a chicken Fri Jan 04, 2013 8:21 am
ARTCOLLINSJR
ARTCOLLINSJR
Q: If it takes 1/2 a chicken 1/2 a day to lay 1/2 an egg, how long does it take a monkey with a wooden leg to kick all the seeds out of a dill pickle?
A: 5 because peanut butter can't climb telephone poles.
Why do I remember this from junior high school, Lexington, Massachusetts 1967?
