1 Oil pressure warning lamp Sun Aug 16, 2009 4:49 pm
Kerswellcrank
Hi folks,
the oil warning lamp on my K100LT doesn't come on when I switch on the ignition (before starting the engine).
If I earth the wire which goes to the oil pressure switch/sensor, the lamp then lights up, so am I right in assuming the pressure switch is simply faulty and a replacement will fix the problem ..... Or might it not be that straightforward?
Is it possible to test the pressure switch itself?
Many thanks,
Steve.
Many thanks,
Steve.
