1Back to top Go down   Replace oil sight glass Empty Replace oil sight glass Tue Dec 11, 2012 3:52 pm
George R
Following on from Ajay's post about the above, I have just replaced the oil sight glass using a slightly different method which does not require drills or broken plastic or oil ontamination. Wait until service is due then drop the oil then the filter as usual. If you look from underneath, from the left side of bike through the sump you will see the oil sight glass on the right sump wall. With a long screwdriver or preferably the small end of a 1/4 inch extension, hit the the glass (may need a rap from a light hammer if tight). It will pop out without damage. Thoroughly clean the recess then a very light coat of dreibond on the seal. then push home with the appropriate socket. Wait 12 hours to cure then refill with new oil. Job done: no possibility of contamination. The other purpose of the oil sight glass is if there is a high over pressure in the lower half of the engine, that pressure has a method of release.
Last edited by George R on Wed Dec 12, 2012 7:53 pm; edited 2 times in total (Reason for editing : spelling!)
2Back to top Go down   Replace oil sight glass Empty Re: Replace oil sight glass Wed Dec 12, 2012 6:32 pm
Good to know George. Thanks for posting.
Replace oil sight glass Ir-log1188....May contain nuts!Replace oil sight glass Ir-log11
K75RTP - 1994
3Back to top Go down   Replace oil sight glass Empty Re: Replace oil sight glass Wed Dec 12, 2012 7:03 pm
That sounds way easy and quite logical George.
Looking forward to doing next time.
KKlompy Replace oil sight glass 2854237993
Replace oil sight glass Au-log10
