Number of posts : 7969
Bikerboy
Some sationery stores, and Eleclerc/SuperU for example sell kits for framing your own posters and most of them use sheet polycarbonate. An A3 size might do. Car headlights are usually curved which allows manufacturers to use thinner sheet as the curve gives strength and rigidity. The K headlamp unit is quite flat so you might need some extra thickness. I have seen it bent with a little heat but you must be careful, too much and it goes milky. I have not taken a K headlamp apart but they do seem to use the same stainless steel clips used on Citroen/Peugeot headlight units to keep the glass lens in place. You might need a little extra thickness at the edges as the glass lens may have little ridges or a raised edge to hold the clips in place. The biggest issue I see with polycarbonate is how they go cloudy and get scratched so maintenance is important.
HoverK100 has made a very important suggestion, but you wont get that in Eleclerc or SuperU.
Its not a big deal to post some over to you if we find it.
92KK
1971 Yamaha 125 YAS-1
