Had a play with the bike on Friday with Mr Klompy.
Pulled the alternator a few times and played with the coils.
Today.
The horn does not work.
The right indicator does not work.
The left indicator does not blink unless I hold on the switch.
The left indicator blinks if I hold on the right switch.
Relay clicks when I turn on the indicator.
The hazard lights work.
Brake lights work.
Lights work. High/low/pass
All the fuses are ok.
Standing on one leg does not help.
rossco
Recheck fuse #7 and the circuit associated with it. It is the usual culprit. Don't just look measure them and check the socket it goes into for corosion as well.
Rick G wrote:Recheck fuse #7 and the circuit associated with it. It is the usual culprit. Don't just look measure them and check the socket it goes into for corosion as well.
Rick, you just paid for your wheel storage for another month.
Fuse was blown, though looked to be perfect.
Ride time.
rossco
I assume you are now either standing on two legs or on none. That Rick knows a fair bit.
ainsjac wrote:I assume you are now either standing on two legs or on none. That Rick knows a fair bit.
As soon as the lights were fixed I was on no legs as I went for a ride and now I am still on no legs as I sit and type.
Yes Stan, that Rick does know a fair bit.
how did she go what with the fixed leaks, fixed coil, carb balance fresh fuel etc etc? and fuses......
Last edited by Klompy the grey brick on Sun Dec 02, 2012 4:23 am; edited 1 time in total (Reason for editing : fuses)
KKlompy No horn. No right indicator (Resolved) 2854237993
No horn. No right indicator (Resolved) Au-log10
