1 Hot fuel pump Wed Oct 31, 2012 12:55 pm
Adiwan Djohanli
Yesterday I tuned up my K100RS. After having the engine running stationary for around 30 minutes, the engine was suddenly slowing down fast and off.
I thought it was the battery but I found out it was the fuel pump stopped running and the fuel and the pump inside were very boiling hot. I believe the fuel pump is faulty.
A friend suggested to me to replace it with fuel pump for Peugot 405 series. He says that it is of the same diameter so it will fit into the holder nicely but a bit shorter than original.
Another friend has successfully replace the fuel pump with the unit used in Toyota Avanza (a small 1000cc / 1300cc SUV). This unit is smaller diameter than BMW original.
Tomorrow I am going to check the suggestion and I will update the result.
Good luck to me.
Good luck to me.
Adiwan Djohanli
Jakarta-Indonesia[i]
