1Back to top Go down   FPR and injectors alternatives Empty Injector alternatives Sun Aug 07, 2011 6:45 pm
Hover K100
Hover K100
I'm having problems with my injectors caused by a failing fuel pump. Are there any other injectors that suit the K100 other than the ford truck type?
BTW two craft in this video use K100 engines https://www.youtube.com/user/HoverIreland#p/a/u/0/0ZeXyp1gyKc
Mine is at 0:29
https://www.youtube.com/user/HoverIreland?feature=mhee
2Back to top Go down   FPR and injectors alternatives Empty Re: FPR and injectors alternatives Sun Aug 07, 2011 6:51 pm
Click on this link for an idea of what's out there....he even specifies the flow rate and offers 'uprated' versions for older K's.
http://www.euromotoelectrics.com/category_s/43.htm
Here's an eBayer from Idaho USA with a very good price on a set of four.
http://cgi.ebay.com/ebaymotors/BMW-K100-Motorcycle-Reconditioned-Fuel-Injectors-_W0QQcmdZViewItemQQhashZitem2eb55e9034QQitemZ200611369012QQptZMotorcyclesQ5fPartsQ5fAccessories
Great little video of the hovercraft, too.
3Back to top Go down   FPR and injectors alternatives Empty Re: FPR and injectors alternatives Sun Aug 07, 2011 9:15 pm
The Ford injectors that are the same and available here in Oz are from the 5lt V8 of 1995 era they were used in the Mustang of the same period.
The engines were made in US and used in many of the cars there and here. The fuel pumps from that Mustang are a good replacement for the K100.
I am not sure if they were used in UK or anywhere in Europe.
4Back to top Go down   FPR and injectors alternatives Empty Re: FPR and injectors alternatives Mon Aug 08, 2011 2:39 pm
Hover K100
Hover K100
Thx for the replies, it would be quite hard 5l V8 here Very Happy, I've gone through the european list but cant find many with the same flow and impedence. I know BMW 323 from the 80's had someting similar.
Anyway I have found a seller here in Ireland with some K injectors which he will swap for some R parts I have so looking good but would still like some alternatives for future reference.
We run external fuel pumps and I found one from an old Merc that works just fine.
The problem was caused by the craft not having a high pressure filter and a failing fuel pump chucked bits into the injectors. Stupid me
6Back to top Go down   FPR and injectors alternatives Empty FPR and injectors alternatives Mon Sep 03, 2012 12:50 pm
VPutin
VPutin
Diging Inet in searching of FRP and injectors articles found couple things, seems to be possible replacement of original ones. (because of the price of original one, and (mainly) long delivery time, at least here, in Russia)
FRP
0 280 160 221 - comes to Opel and some other cars
2.5 Bars
pretty same as original one, but with little problem to fix it.
FPR and injectors alternatives Img_0110
injectors
Bosch 0 280 150 716
according Bosch site, they use it for K100'90 for some time and also for K1, which my bike got same engine.
But original article from BMW give another bosch injectors for all K-bikes (same one for all models/years)
Does somebody study these articles as possible replacement of original ones?
7Back to top Go down   FPR and injectors alternatives Empty Re: FPR and injectors alternatives Mon Sep 03, 2012 12:57 pm
G'day Mr President.
Here's a link to one article about injector alternatives. Say hello to Mr Medvedev, or are you two not speaking lately?
FPR and injectors alternatives 652573
http://k100rt.aforumfree.com/t2473-injector-alternatives
8Back to top Go down   FPR and injectors alternatives Empty Re: FPR and injectors alternatives Mon Sep 03, 2012 1:54 pm
ReneZ
ReneZ
Is THIS something that might help?
Rene
BMW K100 - 1985 (0030029) Scotland FPR and injectors alternatives Rain
9Back to top Go down   FPR and injectors alternatives Empty Re: FPR and injectors alternatives Tue Sep 04, 2012 2:24 am
VPutin
VPutin
Two Wheels Better wrote:G'day Mr President.
Ooh Gees, there is no place to hide... )
unfortunately such tables (which you easily can find alot all over Inet) do not care required information. Like one you mentioned, where is no info about our regular injector ...705. so there is no data to compare.
So basic data you shouls find to campare is form-factor (that mean size and connector type mostly), resistance, productivity. But also is qite importants injector "reaction" speed - something like speed of opening, but this data is really hard to find.
So, only one alternative I found was ...715 injectors, that goes to 3series BMW cars - which chipper and can be easily found, at least, here in Russia
10Back to top Go down   FPR and injectors alternatives Empty Re: FPR and injectors alternatives Tue Sep 04, 2012 4:06 am
ReneZ
ReneZ
Don't forget to look at the pressure they're intended for. The amount listed is in association with a certain fuel rail pressure. Ours are for 2.5 Bar, quite a few of the BMW car ones seem to be for 3.0 Bar.
Rene
11Back to top Go down   FPR and injectors alternatives Empty Re: FPR and injectors alternatives Tue Sep 04, 2012 8:17 am
VPutin
VPutin
VPutin wrote:
FRP
2.5 Bars
One thing that do not let me sleep well
is will be ok to use plastic clamp with high temperature of engine, or better use metal one???
12Back to top Go down   FPR and injectors alternatives Empty Re: FPR and injectors alternatives Wed Sep 05, 2012 3:35 am
ReneZ
ReneZ
I personally would always go for proper steel (stainless..) clamps, but you need to look at the pressure in the line as well. For the return probably plastic could be used, I wouldn't for the pressurised lines.
Rene
13Back to top Go down   FPR and injectors alternatives Empty Re: FPR and injectors alternatives Wed Sep 05, 2012 4:47 am
VPutin
VPutin
ReneZ wrote:I personally would always go for proper steel (stainless..) clamps, but you need to look at the pressure in the line as well. For the return probably plastic could be used, I wouldn't for the pressurised lines.
that's for sure for hose clams,
but my question, actualy, was about calmp on the photo, wich hold FRP to those bracket.
14Back to top Go down   FPR and injectors alternatives Empty Re: FPR and injectors alternatives Wed Sep 05, 2012 5:44 am
Hover K100
Hover K100
At the moment I'm running on a set of injectors from a mid 90's BMW 316 or 323 and the engine starts and runs very well indeed. I'll check for the injector number later. They are really cheap around here because everybody tries bigger injectors in that model car!!
15Back to top Go down   FPR and injectors alternatives Empty Re: FPR and injectors alternatives Mon Oct 01, 2012 8:38 am
VPutin
VPutin
VPutin wrote:Diging Inet in searching of FRP and injectors articles found couple things, seems to be possible replacement of original ones. (because of the price of original one, and (mainly) long delivery time, at least here, in Russia)
FRP
2.5 Bars
injectors
Bosch 0 280 150 716
put mentioned articles on bike.
injectors runs well
FPR seems run well also...
qiute cheaper according original ones.
16Back to top Go down   FPR and injectors alternatives Empty Re: FPR and injectors alternatives Mon Oct 01, 2012 11:49 am
In my 8V K100RS with K1100 35mm throttle bodies I am using the K11 injectors. The original K100 injectors are rated to flow 133cc of fuel per minute and the K11/K12 series flow 150cc pm. I have not stuck a sniffer up the bunghole to check the mixture for emissions. There is a smidge more soot around the tailpipe egress hole but the bike runs cleanly and fuel mileage is about the same as before.
