1Back to top Go down   rear shock advice Empty rear shock advice Wed Aug 29, 2012 6:44 pm
ali2908
ali2908
After riding the bike for a few weeks now I have noticed that the rubber at the bottom of the rear shock inside the spring has perished and broken apart. Does any one know if this shock rebuild kit on ebay is suitable for the stock shock absorber 1985 K100 RS?
http://www.ebay.co.uk/itm/Marzocchi-Shock-Rebuild-kit-for-BMW-K100-part-number-850115-/280902630611?pt=UK_Motorcycle_Parts&hash=item416719fcd3#ht_500wt_1288
Regards
Ali
1985 K100RS
2002 K1200 RS
2Back to top Go down   rear shock advice Empty Re: rear shock advice Wed Aug 29, 2012 7:43 pm
Rjtrucker
The original shock from a k100 is not rebuildable. The rubber bumper on the bottom can be replaced but you will need a way to compress the spring.
Ron S
NJ USA
74 R90/6 cafe project
93 K11LT
85 K100RS
85 K100RS turbo project.
And a load of K100 projects and parts.
3Back to top Go down   rear shock advice Empty Re: rear shock advice Wed Aug 29, 2012 7:46 pm
I think it`s the rubber in the mounting eye he have in mind.
4Back to top Go down   rear shock advice Empty Re: rear shock advice Wed Aug 29, 2012 8:13 pm
Rjtrucker
He did say inside the spring.
Ron S
NJ USA
93 K11LT
85 K100RS
5Back to top Go down   rear shock advice Empty Re: rear shock advice Wed Aug 29, 2012 8:19 pm
Sorry, time to visit my optometrist.......again.
6Back to top Go down   rear shock advice Empty Re: rear shock advice Thu Aug 30, 2012 3:51 am
nino
Ali, shock is rebuildable if you find some specialist in neighborhood. I have two workshops in circle of 50 km from Zagreb which do that job for 50 euros, so I believe in UK is easier to find than here. Rubber damper inside spring prevents damage when spring compress to the end (metal to metal contact).
On motorworks you can find original bilstein absorber (just inner telescope) for cca 100 pounds.
Regards
7Back to top Go down   rear shock advice Empty Re: rear shock advice Thu Aug 30, 2012 3:58 am
ali2908 wrote:After riding the bike for a few weeks now I have noticed that the rubber at the bottom of the rear shock inside the spring has perished and broken apart. Does any one know if this shock rebuild kit on ebay is suitable for the stock shock absorber 1985 K100 RS?
Rebuilding a K100 shock is a job for an expert. It needs to be opened using a lathe and then rewelded after the repair and they usually dont last.
The RAM SHOX are the best value you will get http://www.realmengineering.com/page15.html
8Back to top Go down   rear shock advice Empty Re: rear shock advice Thu Aug 30, 2012 4:09 am
ali2908
ali2908
Thanks again for the advice I will look at the Motorworks option as I have spring compressors. Would the broken rubber give handling problems?
Ali
Regards
Ali
1985 K100RS
2002 K1200 RS
9Back to top Go down   rear shock advice Empty Re: rear shock advice Thu Aug 30, 2012 4:11 am
Probably not but if you hit a real bad bump and bottom the shock it could break around the seal or just blow the seal out.
10Back to top Go down   rear shock advice Empty Re: rear shock advice Thu Aug 30, 2012 4:27 am
nino
Ali, to avoid damage, you can mount peace of rubber inside spring. Find rubber tube 30 mm in length, cut it longitudinally and try to push between spring, around the absorber shaft. Thats exactly what I did, before rebuilding shock.
Regards
11Back to top Go down   rear shock advice Empty Re: rear shock advice Thu Aug 30, 2012 5:33 am
dalderton
dalderton
I have a RAM shock as mentioned above and am very happy with it.I did contact a chap in Penrith who would rebuild my standard one in the original case for anyone who wanted it to look original but it was more expensive than importing the Ram Shock from U.K
Regards Dennis.
1985 K75c Stock other than Realm Engineering Rear Shock.
12Back to top Go down   rear shock advice Empty Re: rear shock advice Tue Sep 04, 2012 1:58 pm
mikidymac
mikidymac
If you are refering to the rubber bottoming cone that is on the shock shaft, I had the same problem on my Polaris SXS. If you can remove the spring you can heat the eye that connects to the shock shaft enough to loosen the thread lock and it should unscrew easily but do not burn the rubber eye bushing then the rubber cone will slide off. I found replacement ones from Energy Suspension. Make sure to use red threadlock when you reinstall the eye. This is assuming that the eye threads on the shaft and is not welded.
13Back to top Go down   rear shock advice Empty Re: rear shock advice Tue Sep 04, 2012 4:23 pm
ali2908
ali2908
I have ordered a new Hagon shock which should arrive tomorrow, so hopefully back on the road tomorrow night.
Thanks again for the helpful advice.
Ali
Regards
Ali
1985 K100RS
2002 K1200 RS
