1 sudden death for my k100...or is it just sleeping? Wed Oct 31, 2012 4:38 pm
diversity48
any suggestions? 1985 k100rs...stop for a water at the local gas station after riding fairly hard for the last 4-5 hours. after filling with gas, let the bike sit on the sidestand for close to an hour. come back out, put the key in, and all i get is engine turning over strong, but NO START. battery spins it like crazy, but NO START. the only unusual symptom is gasoline appearing to be leaking out of the exhaust pipe, right at the junction beneath the footpeg, left side. as near as i can tell, the gasoline really is leaking from the exhaust pipe connection. after several more attempts to start it, it fires up and runs normally. after riding about another 42 miles, make another stop, again leaving it on the sidestand, and it appears to have stopped leaking. half hour later, come out and try starting it again, same thing happens: gas begins leaking from the same spot at a fairly constant drip, and the bike won't start. several more attempts, NOTHING. spins like crazy, but absolutely refuses to fire. take all the plugs out and they are wet with gas. after allowing time for them to dry, and a few spins to blow gas out of the then open spark plug holes, put one plug back in its holder and there is spark. put all the plugs back in and still no start. only unusual occurence happened just before the last gas fill. i had practically run it out of gas and in fact it was lurching pretty badly as i pulled up to the pump. i can't imagine that would have caused the problem...any suggestions from the gurus here? help me solve my dilema??
