1Back to top Go down   Dashboard question Empty Dashboard question Fri Aug 17, 2012 4:11 pm
claudejones
Does anyone know if the Dashboard from an '85 K100RS will fit in a K100RT - this one doesn't appear to have any holes for the instruments, but those could be drilled if the dash will bolt in to the fairing. If anyone is interested in selling one of these, I'm in the market - my bike tipped over in a parking lot this week while I was stretching a bungee chord over something and I cracked the dash all the way across on one side
2Back to top Go down   Dashboard question Empty Re: Dashboard question Fri Aug 17, 2012 5:57 pm
If it`s part 12 and 26 you have in mind, it`s quite different RS vs. RT.
Dashboard question Interi10
3Back to top Go down   Dashboard question Empty Re: Dashboard question Fri Aug 17, 2012 6:04 pm
Comberjohn
Comberjohn
I agree.
I think it would be much easier to pick one up on eBay or from a breaker.
Its the kind of spare that isn't normally in much demand and would be cheap to buy.
It would be difficult to think of a scenario where you could damage it!
4Back to top Go down   Dashboard question Empty Re: Dashboard question Fri Aug 17, 2012 7:55 pm
claudejones
The dashboard I found was on eBay. I'm pretty sure as others have said, it won't work on my RT as it is specifically stated it's for an RS - I'm watching eBay for this part and just posted a request in the buy and sell section of this forum...
5Back to top Go down   Dashboard question Empty Re: Dashboard question Fri Aug 17, 2012 9:15 pm
claude ...they can be repaired
with a soldering iron no less
Dashboard question 2012-092
Dashboard question 2012-091
6Back to top Go down   Dashboard question Empty Re: Dashboard question Fri Aug 17, 2012 10:40 pm
claudejones
That's an option - I bet a layer of JBWeld on top of that solder work would make it even stronger
7Back to top Go down   Dashboard question Empty Re: Dashboard question Fri Aug 17, 2012 11:22 pm
8Back to top Go down   Dashboard question Empty Re: Dashboard question Sat Aug 18, 2012 2:47 am
club_c
club_c
Claude, check beemerboneyard.com for used stuff.
1988 K100RS SE VIN 01477554
9Back to top Go down   Dashboard question Empty Re: Dashboard question Mon Aug 20, 2012 11:04 am
claudejones
club_c wrote:Claude, check beemerboneyard.com for used stuff.
Already did, thanks.
10Back to top Go down   Dashboard question Empty Re: Dashboard question Mon Aug 20, 2012 11:20 am
claudejones
Here's the part I need, #2
Dashboard question Dashboard
11Back to top Go down   Dashboard question Empty Re: Dashboard question Mon Aug 20, 2012 11:34 am
If it's either of these two bits Claude (not including the speakers)...
Dashboard question Img_0810
I've got them left over from my electric screen conversion. Let me know and I'll check out the postage cost at my local post office.
88KE
Dashboard question Ir-log1188....May contain nuts!Dashboard question Ir-log11
K75RTP - 1994
12Back to top Go down   Dashboard question Empty Re: Dashboard question Mon Aug 20, 2012 11:49 am
claudejones
That lower one on the seat 'could' be the one. Depends on what's under those speakers. Mine has a gas gauge on the left, and a temperature gauge on the right. Is there a part number stamped on your part? Several posts back, I showed the microfiche picture of what I need and there's a part number #46631453939 which I'm pretty sure is the right one - doesn't mean other part nos. wouldn't work, but, I just don't know.
Dashboard question MyDashboard
13Back to top Go down   Dashboard question Empty Re: Dashboard question Mon Aug 20, 2012 12:17 pm
On studying your picture there Claude, yours looks different to mine in that the panel where the gauges are mounted is flat. On mine the speaker is mounted on a profiled block to present them squarely.
With the speakerts removed there is also a 3.5 inch hole to recess the speakers on mine, which would be way too big for the guages. Close....but no cigar I think!
K75RTP - 1994
14Back to top Go down   Dashboard question Empty Re: Dashboard question Mon Aug 20, 2012 12:50 pm
Center cover predrilled for gauges, part # 46 63 1 453 939.
Center cover predrilled for speakers, part # 46 63 2 303 230.
Clean center cover w/o holes, part # 46 63 1 453 173
You could use the for speakers, and make your own adapter plates for the gauges.
15Back to top Go down   Dashboard question Empty Re: Dashboard question Mon Aug 20, 2012 1:09 pm
claudejones
Inge K. wrote:Center cover predrilled for gauges, part # 46 63 1 453 939.
I found a brand new one at big BMW parts house in the U.S. The above part number is the same as the one I came up with. Can't use the speakers because I don't have a radio (and don't really want one). Thanks for your input.
On a different note, can anyone summarize what I have to remove in order to replace that part?
16Back to top Go down   Dashboard question Empty Re: Dashboard question Mon Aug 20, 2012 1:26 pm
screen ...bridge , side pockets and thats about it
carefull with the connectors on the back of the guages
and it should lift out with care
they have a bit of a gasket -rubber seal around the front edge of the dash section usually
17Back to top Go down   Dashboard question Empty Re: Dashboard question Mon Aug 20, 2012 1:33 pm
claudejones wrote: Can't use the speakers because I don't have a radio (and don't really want one). Thanks for your input.
What I did have in mind was making adaptor plates covering the bigger holes,
after the speakers have been removed.
And then mount the gauges in these adaptor plates.
But it doesn`t matter now, when you luckily enough have found the correct part.
claudejones wrote:On a different note, can anyone summarize what I have to remove in order to replace that part?
The genuine workshop manual you can download here.
