1Back to top Go down   Sump plug gasket? Empty Sump plug gasket? Fri Aug 10, 2012 6:03 am
dalderton
dalderton
My K75 relies on face to face sealing between sump plug and sump. This was how it was when I aquired it. It looks as if it may have an O ring originally or perhaps an alloy washer. It did not leak until I changed the oil a couple of days ago but it has started to leak now. I tightened it up a tad more and I think it has stopped but I dont like going too tight in alloy. Any info would be appreciated.
Regards Dennis.
2Back to top Go down   Sump plug gasket? Empty Re: Sump plug gasket? Fri Aug 10, 2012 6:14 am
yes indeed there should be a sealing washer in there .
i use a fibre washer ...but the real recomendation is for a brass - copper one i think ....makes sence anyhow !
3Back to top Go down   Sump plug gasket? Empty Sump plug Gasket Fri Aug 10, 2012 6:19 am
Lazyboy
Lazyboy
Hi dalderton, My K100 RT sump plug has a compression washer that I have not replacecd after many oil changes BUT I always use a smear of RTV Silicon Gasket Maker on the thread of the sump plug and have never had a oil leak I also feel that it is a insurance against the plug coming loose.
1984 BMW K100RT
Bikes Name: Lazyboy
4Back to top Go down   Sump plug gasket? Empty Re: Sump plug gasket? Fri Aug 10, 2012 7:09 am
It's an aluminium washer, part number 07 11 9 963 300. 18x22mm
http://realoem.com/bmw/showparts.do?model=0503&mospid=51751&btnr=11_4677&hg=11&fg=13
5Back to top Go down   Sump plug gasket? Empty Re: Sump plug gasket? Fri Aug 10, 2012 7:45 am
Agerbundsen
Agerbundsen
Dennis, watch out with the overtightening - K-bike sump plugs are somewhat notorious for getting stuck to the point of not being able to get them out with the internal hex wrench.
New alu compression washer each time and no more torque than prescribed. DAMHIKT
6Back to top Go down   Sump plug gasket? Empty Re: Sump plug gasket? Fri Aug 10, 2012 7:54 am
I do my own car servicing and I have to replace a compressible copper washer on the sump plug at every oil change.
I can buy them cheaply in packs of 10 and my car ones fit the K100. Aluminium will work just as well, both are soft metals and compressible. The plug does not need to be excessively tight, be careful not to strip the threads.....
7Back to top Go down   Sump plug gasket? Empty Re: Sump plug gasket? Sat Aug 11, 2012 12:29 am
dalderton
dalderton
Thanks to all who replied. I made a copper one today and fitted it so all is well.
Regards Dennis.
