1Back to top Go down   Stuck speedo drive Empty Stuck speedo drive Sat Aug 11, 2012 1:01 pm
ali2908
ali2908
My speedo stopped working last week, checked and cleaned everything with deoxit including speedo unit, but I cant get the drive out of the transmission. I don't know how to remove the unit, I don't want to break it, there is nothing to grip it with. any ideas how to get it out?
Stuck speedo drive Beemer10
Does it matter which way the two wires are connected as I could not get the cover off with the wires connected.
Regards
Ali
1985 K100RS
2002 K1200 RS
2Back to top Go down   Stuck speedo drive Empty Re: Stuck speedo drive Sat Aug 11, 2012 1:18 pm
twincarb
twincarb
It's just a push in connector, which should only be held in with the one bolt some anti sieze may be needed as it may be stuck with dirt road grime etc
Yamaha Thundercat
Stuck speedo drive 169042Stuck speedo drive 169034
3Back to top Go down   Stuck speedo drive Empty Re: Stuck speedo drive Sat Aug 11, 2012 1:35 pm
nino
Try to push it up with some small screwdriver. Carefully, slowly from all sides. Good luck
4Back to top Go down   Stuck speedo drive Empty Re: Stuck speedo drive Sat Aug 11, 2012 1:57 pm
ali2908
ali2908
It has 2 wires which push in to a hole on either side of the unit.
Regards
Ali
1985 K100RS
2002 K1200 RS
5Back to top Go down   Stuck speedo drive Empty Re: Stuck speedo drive Sat Aug 11, 2012 8:47 pm
What I see is a sensor that is busted and as it is the older type you are fortunate it lasted this long. You dont need to be too gentle getting it out because it is already shagged. There is one on ebay so grab it as it is a fair price http://www.ebay.com/itm/K1-K1100-K75K100-Speed-Sensor-Pulse-Generator-/160825554820?hash=item2571f33784&item=160825554820&pt=Motorcycles_Parts_Accessories&vxp=mtr
6Back to top Go down   Stuck speedo drive Empty Re: Stuck speedo drive Sun Aug 12, 2012 2:34 am
ali2908 wrote:...but I cant get the
drive out of the transmission....
Of course, you must have meant the final drive.
That eBay unit is secondhand. If a new one is desired I've one listed here:
http://k100rt.aforumfree.com/t4202-misc-oem-k-parts-for-sale
Postage to Scotland from the West coast of the US can't be too much...in fact...
http://ircalc.usps.com/MailServices.aspx?country=10149&m=13&p=0&o=1&mt=19
A reasonable option in your situation.
Or, Motorworks have a new one for £60.46 (about USD$95.00) including VAT but not postage.
