1Back to top Go down   Fuel leak Empty Fuel leak Thu May 16, 2013 1:00 am
I just filled my tank with petrol after I payed and returned to my bike I found a puddle of petrol under it, I thought it may have been there from a previuos spill but half way home I had petrol all over both boots, I drained tank when I got home but petrol was every where and running out of radiator shroud. I hope only a hose has let go it was pouring out evreywhere. Under the motor and my boots are now clean.
2Back to top Go down   Fuel leak Empty Re: Fuel leak Thu May 16, 2013 1:13 am
Lucky it didnt go woof and turn into a dog. Sounds like the hoses are past the use by as they are on many vehicles.
3Back to top Go down   Fuel leak Empty Re: Fuel leak Thu May 16, 2013 1:31 am
sounds like the return line let go or cracked waz
you may have to undo both sides lowers to replace it fully ....but start on the injector side and see how it all looks
good luck ...
4Back to top Go down   Fuel leak Empty Re: Fuel leak Thu May 16, 2013 6:47 am
Thanks I have removed both sides got bits every where, tank off and OK so must be return line gunna have to remove air box to get at the other end of the hose I think, it is caught on somthing a can not feel or see what.
5Back to top Go down   Fuel leak Empty leaker Thu May 16, 2013 6:55 am
mawhera
mawhera
sounds like a hose rupture to me ? lucky she never blew i spose. Rick :cherry:
6Back to top Go down   Fuel leak Empty Fuel leak Fri May 17, 2013 12:14 am
Waz, best thing is to buy a meter or so of fuel injection rated hose and do them all, chances are the tank to fuel rail, and fuel rail to fuel pressure regulator will need replacing to be safe. I got mine from Auto Pro.
Sing out of you need some help. (that's a first for me).
7Back to top Go down   Fuel leak Empty Re: Fuel leak Fri May 17, 2013 2:31 am
Thanks Bob
Good idea, I got new hose and will replace them all as soon as I get the mungral air box out.
8Back to top Go down   Fuel leak Empty Re: Fuel leak Fri May 17, 2013 3:19 am
The air box on a 8v is chicken $hit you should try to get one out of a 16v
9Back to top Go down   Fuel leak Empty Re: Fuel leak Fri May 17, 2013 3:35 am
Well I would have no hope then, I have one bolt out and the air filter out and my hands are too big to even feel the other allen bolt, have to be nice to the cook she has little hands. Going back out for round 3.
10Back to top Go down   Fuel leak Empty Re: Fuel leak Fri May 17, 2013 3:42 am
Remove the top section by releasing the clamp on the small end of the tube to the plenum and then the top will move aside to get the lower part out. Easiest to use a 7mm socket and 1/4 drive ratchet. That can be difficult first time but if you leave the small bolt on the clamp at about 7 o'clock position then its easy next time.
11Back to top Go down   Fuel leak Empty Re: Fuel leak Fri May 17, 2013 4:52 am
Thanks Rick that worked.
