1Back to top Go down   lost first gear Empty lost first gear Mon Jun 08, 2009 8:08 am
arbalest
I have a 1985 K100 RS with 40k miles. On a long ride yesterday, I lost first gear. I have not had transmission problems, other than the occasional false neutral between 3rd and 4th and 4th and 5th. When trying to downshift to first, the shift lever travels farther than it should, and first gear will not engage. Second through fifth is ok, and if I stop the downshift at second, it's ok. The bike has enough torque to start in second. Has anyone else experienced a similar problem? What was the problem and what was the solution?
Thanks,
Mike Lydon
2Back to top Go down   lost first gear Empty Re: lost first gear Tue Jun 09, 2009 4:41 am
boristhebike
boristhebike
Sounds like selector forks or the drum. Gearbox off. Bad luck, but you will sort it out no prob with the expert advice from members here. Good luck. BTB
