madmart
madmart
Can someone tell me how to remove the rubber cover on the handlebars so I can access the top of the fork tubes? I can't see any bolts anywhere.
Under the pad at the reat there are two small bolts that go into the top tripple clamp, they will be either 10mm hex head or 5mm socket head.
3Back to top Go down   How do you access the handlebar bolts k100rs Empty Still cant find them Tue Jul 31, 2012 9:04 am
madmart
madmart
I have had a good look and can't see or feel any bolts. I just want to be able to top up the fork legs. Do you have to take off the brake and clutch lever, or can it be done any other way?
Martin
Have a look under the lower side of the pad (the upper side is near the instruments, the lower side is near the fuel tank). You have to bend the pad up a bit to see the bolts.
There are 2 bolts as described by Rick G.
5Back to top Go down   How do you access the handlebar bolts k100rs Empty Thanks Tue Jul 31, 2012 3:02 pm
madmart
madmart
Found them. I was looking for bolts that went vertically into the rubber.
Thanks for all your help
