1Back to top Go down   ELECTRIC SCREEN NOT WORKING Empty ELECTRIC SCREEN NOT WORKING Thu Jun 28, 2012 5:07 am
biffo7858
biffo7858
Hi, I am a new member ahving just purchased 1993 k1100LT AND VERY IMPRESSED BY THE FORUM.
I require adviceithe electric screen is not working and I am unable to get hold of a manual locally, can anyone give me advice on how to trace/rectify the fault.
2Back to top Go down   ELECTRIC SCREEN NOT WORKING Empty Re: ELECTRIC SCREEN NOT WORKING Thu Jun 28, 2012 6:00 am
Welcome Biffo!
If you don`t hear the relay inside the fairing clicks when you push the button for up or down movement, the most common problem is the switch (also check the fuses).
It also being quite common that the mechanism is seized due to corrosion and/or lack of lubrication.
Here do you find a lot of info.
Here is some quite importent info about aligning before dismantling.
BTW. You find a lot more info about the screen in that forum in the links, if you search around.
....put your questions in the technical section, where other later on would search.....
3Back to top Go down   ELECTRIC SCREEN NOT WORKING Empty Re: ELECTRIC SCREEN NOT WORKING Thu Jun 28, 2012 6:10 am
biffo7858
biffo7858
Many thanks for prompt reply, I will investigate as shown when I get home this evening and give you an update.
Thanks again.
4Back to top Go down   ELECTRIC SCREEN NOT WORKING Empty Re: ELECTRIC SCREEN NOT WORKING Thu Jun 28, 2012 6:52 am
welcome from Australia Biffo.
If you can't find it here it does not exist.
rossco
5Back to top Go down   ELECTRIC SCREEN NOT WORKING Empty Re: ELECTRIC SCREEN NOT WORKING Thu Jun 28, 2012 8:04 am
biffo7858
biffo7858
Agreed appears to have every awnser
Hope your weather is better the Scotland,11degrees and 50mm of rain forecast today and to contiune 3-5 days so little change of an enjoyable run.
6Back to top Go down   ELECTRIC SCREEN NOT WORKING Empty Re: ELECTRIC SCREEN NOT WORKING Thu Jun 28, 2012 9:55 am
Been about the same here for the last 4 days
7Back to top Go down   ELECTRIC SCREEN NOT WORKING Empty Re: ELECTRIC SCREEN NOT WORKING Thu Jun 28, 2012 12:42 pm
welcome aboard biffo
8Back to top Go down   ELECTRIC SCREEN NOT WORKING Empty Re: ELECTRIC SCREEN NOT WORKING Thu Jun 28, 2012 2:16 pm
Welcome Biffo. Interesting name - people form County Offaly where I was reared are referred to as "Biffo"s over here..."Big Ignorant F@%£ers From Offaly" !! Wink
Skip over to the members intro section and put up an intro there and you'll get access to the downloads section.
Crazy Frog, Robmack and Inge K are your men on electric screens.
88KE
ELECTRIC SCREEN NOT WORKING Ir-log1188....May contain nuts!ELECTRIC SCREEN NOT WORKING Ir-log11
K75RTP - 1994
9Back to top Go down   ELECTRIC SCREEN NOT WORKING Empty Re: ELECTRIC SCREEN NOT WORKING Thu Jun 28, 2012 6:32 pm
Biffo, welcome to the forum. Hope we will have the pleasure of a visit from you to these roads!! Great site.
10Back to top Go down   ELECTRIC SCREEN NOT WORKING Empty Re: ELECTRIC SCREEN NOT WORKING Fri Jun 29, 2012 3:58 am
biffo7858
biffo7858
Hi 88ke i,
I am 6'4" and 20 stone and according to my wife wife you summed me up -she gave me the nickname Biffo she must have done her research.
Great site thanks everyone for warm welcome
11Back to top Go down   ELECTRIC SCREEN NOT WORKING Empty Re: ELECTRIC SCREEN NOT WORKING Fri Jun 29, 2012 8:12 pm
Hi Biffo,
Good to have you with us. Put a post over in the Frame Fairing an dwheels so people see it not everyone reads this section and your best chance of a good answer comes in the spot people read.
12Back to top Go down   ELECTRIC SCREEN NOT WORKING Empty Re: ELECTRIC SCREEN NOT WORKING Fri Jun 29, 2012 10:01 pm
It would be useful to understand the symptoms you are experiencing as it would help with the debugging. For example, is the windshield completely non-functional? Is there power to the control relays?
I wrote a great deal of information in the Windshield Installation thread. This information has some rudimentary debugging information in it as well which might get you started in the right direction. Bench testing the windshield will yield faster results because the components get exposed, allowing you access to test.
13Back to top Go down   ELECTRIC SCREEN NOT WORKING Empty ELECTRIC SCREEN NOT WORKING Sat Jun 30, 2012 9:00 am
Hi Biffo
you could be just like me, I have 3 screens, an original LT, a higher new one and a shorter so called comfort screen. I have to check out the weather forecast to see which one to put on, but they don't break down.
Cheeers RT
14Back to top Go down   ELECTRIC SCREEN NOT WORKING Empty Re: ELECTRIC SCREEN NOT WORKING Sat Jun 30, 2012 4:41 pm
Rick G wrote:Been about the same here for the last 4 days
Difference is Rick ....that's your winter and it our Bloddy summer Crying or Very sad
K75RTP - 1994
15Back to top Go down   ELECTRIC SCREEN NOT WORKING Empty Re: ELECTRIC SCREEN NOT WORKING Sat Jun 30, 2012 8:53 pm
I was wondering when I would get a comment.
Our winters here are glorious we usually get frosty mornings followed by sunny days and probably only 8 - 10 really cold and wet days each winter. That's sunny Queensland.
