1Back to top Go down   cam cover removal Empty cam cover removal Tue Jun 05, 2012 8:08 pm
A bit of advice if you would, sage bretheren of the K forum.....
I'm stuck removing the front cam cover (just being cautious as it's my first time doing this). CAn't seem to get the back plate of the hall effect sensor out, all fastners removed. Also the oil pressure pipe/wire to what and how is it connected - not giving with a gentle tug and I don't want to force either of the above bits. They are all that's standing between me and removing the cover for cam chain inspection and painting.
thanks
88KE
cam cover removal Ir-log1188....May contain nuts!cam cover removal Ir-log11
K75RTP - 1994
2Back to top Go down   cam cover removal Empty Re: cam cover removal Tue Jun 05, 2012 8:18 pm
For clarification purposes, this procedure sounds more like the front timing chain cover than the cam cover, which is the left hand side engine cover.
The oil pressure and water temp switch leads are a pull-off design on the end of the switches themselves. After prising off the rubber boots a gentle twist and tug sideways, as they're the mushroom type (at least one of them is/not pushed straight on), will get them off. The leads then feed through the timing chain cover.
The hall sensor backing plate has two screws in it which you say you've removed. How 'bout a gentle tap with a soft object on each 'side' of the plate in a back and forth motion? It's likely just caught up due to having been fastened there so long. With everything else removed it might come off once you're gently pulling on the timing chain cover. The connector for the ignition is up near the tank, right hand side. I just leave that hanging and tied off somewhere, unless you need it right out of the way. A 'soft' hammer (plastic or rubber) works wonders with aluminium covers when you're having to enforce their eviction notice.
3Back to top Go down   cam cover removal Empty Re: cam cover removal Tue Jun 05, 2012 9:14 pm
Brickee
Brickee
Be sure to scribe where that Hall effect sensor plate is before you take it off, or at least take a picture of it. Otherwise you'll have to reset the timing. From the other posts I've seen, you need special tools to do that. Sorry if I'm stating the obvious.
86 K100RT VIN 0053533
The good news is, I no longer have senior moments. The bad news is, now it's a constant state of mind.
4Back to top Go down   cam cover removal Empty Re: cam cover removal Tue Jun 05, 2012 10:25 pm
Why did you not post this 3 weeks ago Brickee, before I took off the backing plate without a mark or photo?
rossco
5Back to top Go down   cam cover removal Empty Re: cam cover removal Tue Jun 05, 2012 11:14 pm
awww poor rossco .....dang huh ?
always good to get a detailed pic if were pulling apart something new ?
6Back to top Go down   cam cover removal Empty Re: cam cover removal Tue Jun 05, 2012 11:23 pm
Brickee
Brickee
I'm good, but not that good. Here's a piccy I took of mine when I did mine this last winter.
cam cover removal Img_0017
This position, according to the Clymers manual, is the ball park setting. It will run decently at this spot. One of the members posted an excellent how to w piccys on setting up the timing using the right tools within the last week or so. Some time ago, GITH posted some experimentation he did with advancing it even more with good results. He would have more info on that. Hope this helps.
7Back to top Go down   cam cover removal Empty Re: cam cover removal Wed Jun 06, 2012 12:12 am
Oh, that bit. Yeah, I did that. Hope that little white mark didn't rub off yet. I thought you meant the plate at the back with the little notch out of it.
Please tell me that is not the bit you were referring to.
cam cover removal Dsc02713
8Back to top Go down   cam cover removal Empty Re: cam cover removal Wed Jun 06, 2012 7:36 am
Brickee
Brickee
The plate and cup behind the HES will only go on one way, you're safe there. But I have a pic of that if you need it.
9Back to top Go down   cam cover removal Empty Re: cam cover removal Wed Jun 06, 2012 3:43 pm
Yep I scribed a mark with a sharp point on it Before I tinkered but if it all goes pear shaped I've a good Bulgarian bike mechanic a few villages away!
K75RTP - 1994
