1 91 K100RS electricial system shutdown Sat May 26, 2012 3:10 am
jumper2001
For the past couple of years I've been having intermittent electrical problems with my 91 K bike. I traced some to a dirty starter motor, corroded grounds and bad battery, but this one stranded me yesterday. I was riding and the engine cut out like the kill switch had been used. This happened once last year. No lights, no displays, no starter. I managed to get it started again by cycling the ignition switch a number of times, and when I got to my destination, I stopped and restarted it several times successfully, but when it came time to go home, it turned over okay but with no starting, and then completely died except for a dim ABS light. The AGM battery is only 18 months old and starts it just fine. I am suspecting a dirty or bad key switch, which, of course, BMW doesn't stock anymore. Has any one else had this problem? Possible solutions?
