1Back to top Go down   Peggy's K75s Empty Peggy's K75s Sun Feb 03, 2013 1:44 pm
tio Jaimito
tio Jaimito
Peggy's K75s K75_st12
Peggy's K75s K75_po11
Peggy's K75s Texas_10
Krazy Kat. 1985 K100RS Alaskablau 13000miles 8valve "Black Belly"
Peggy's 1987 K75s Columbia Grey 9500miles 6 valve.
Peggy's K75s K100_m12
Peggy's K75s K75_po12
Peggy's K75s Basil_10
http://www.nachicagonorth.com
2Back to top Go down   Peggy's K75s Empty k75 Sun Feb 03, 2013 1:47 pm
ARTCOLLINSJR
ARTCOLLINSJR
Is that the bike we saw for sale last week?
Looks very nice.
3Back to top Go down   Peggy's K75s Empty Re: Peggy's K75s Sun Feb 03, 2013 1:51 pm
tio Jaimito
tio Jaimito
Yes Art, Excuse my fumbling with the forum. My wife and I unloaded the bike last night, when I got back from TX. With a little battery charging I got it to start. Between sitting and condensation I consider that good news. Would not respond to throttle accelleration, and would die. But it runs and starts. A good first step.
UJ
tio Jaimito
tio Jaimito
I was doing alot of reading this morning. I am soliciting suggestions for where to start. This morning after sitting in a warm garage and having the battery charged she started right up with the half choke and idled. I can hear the valve train, the fuel pump. When I give her the slightest amount of throttle, I can hear one of the cylinders not fire. If I persist on the throttle, she completely dies. Idles and starts like a champ. I know the battery is an 18A/h wet cell battery but it does get her started. What is my next move here. Thoughts?
UJ
5Back to top Go down   Peggy's K75s Empty Re: Peggy's K75s Sun Feb 03, 2013 2:47 pm
maybe a few things uj
first that comes to mind is possibly the tps (possibly it is shorted out ?)
i would dissconnect it and see if she revs up past 2000
without any other information is just a guess
many things need to be checked though
fuel delivery ...presure ...spark leads breaking down ...spark plugs can give a clue to state of tune , rich- lean
crankcase breather to plenum .. rotten fuel ...etc ...so many things that can be seen by eye
6Back to top Go down   Peggy's K75s Empty Re: Peggy's K75s Sun Feb 03, 2013 4:13 pm
AJ.Valente
AJ.Valente
Well, reading from my friendly Clymer:
a. Improper timing
b. Improperly gapped plugs
c. Defective spark plug wires
d. Loose or corroded electrical connections in ignition system
e. Bad fuel pump or fuel injectors
f. Fuel system pressure regulator not functioning properly
g. Weak or faulty fuel injection control unit
h. Obstucted fuel line
7Back to top Go down   Peggy's K75s Empty Re: Peggy's K75s Sun Feb 03, 2013 4:41 pm
tio Jaimito
tio Jaimito
Thank you Charlie and AJ
I will look into these things.
After reading responses, Clymer, forums etc, I suppose I will start with a good cleaning and inspection. I will try a quick jolt of starting fluid around the throttle body the momento I give it the gas to see if I am sucking air some where. If that doesn't catch a fish, I'll look in and under the tank at connections and fuel delivery filter and pump. The TPS is a good start as well, thanks to all for the guidance and hand holding. I will also then be able to look and hoses and rubber for possible vacuum leaks.
Uncle Jim
8Back to top Go down   Peggy's K75s Empty Peggy's K75s Sun Feb 03, 2013 4:54 pm
Well done guys, I like that silvery grey (matches my hair).
Pull the spark plugs one at a time and have a look, one of them might be different (wet, black, white) and if so work back from it through the ignition lead, no breaks or shorting,
check the connection of it to the coil.
Also check the spark plug caps, make sure those little metal
screwon tops are there as shorts can occur in the top of the cap. Check for Grunge and don't let Inge see how dirty they are.
9Back to top Go down   Peggy's K75s Empty Re: Peggy's K75s Sun Feb 03, 2013 7:06 pm
Put a new filter in first up and make sure the pre pump filter is not full of crud.
10Back to top Go down   Peggy's K75s Empty Re: Peggy's K75s Sun Feb 03, 2013 7:30 pm
Hmm...it run at idle, but dies with the smallest amount of throttle.....
Just been standing at the airport parking for some weeks....
Much mice or similar creatures in that area?
Check the hose between the plenum and airfilter housing.
11Back to top Go down   Peggy's K75s Empty Re: Peggy's K75s Mon Feb 04, 2013 6:17 pm
tio Jaimito
tio Jaimito
Will do, thank you.
Hose between plenum (engine case) and air box.
Fuel Filter and tank inspection
Clean relays and connections with Caigs
I have homework.
UJ
12Back to top Go down   Peggy's K75s Empty Re: Peggy's K75s Mon Feb 04, 2013 6:33 pm
tio Jaimito wrote:Hose between plenum (engine case) and air box.
Peggy's K75s Slange10
13Back to top Go down   Peggy's K75s Empty Peggy's bike update. Sat Mar 23, 2013 10:05 pm
tio Jaimito
tio Jaimito
Thank you to all who have given advice on this thread. And thanks to those who helped me with parts. What we did find were the following things:
The battery was the wrong size and was an 18 amp/hr. So just to take that out of the equation we got the BMW 25amp/hr unit. There was a faulty earth on the Throttle body sensor, BMW analysis machine narrowed the search down. Hard to find, easy to fix. The breather tube to the crankcase was cracked on the back side. Replaced this
Most strangely the timing was 16 degrees off. Previous Owner trying to fiddle.
I took her for a nice 37 deg. F 40mile run this morning. She ran great.
Some noted observations on the maiden voyage:
1987 Columbia Grey K75S
The Instrument Pod seems to wobble much more that the K100rs. Odd? (I will search forum on this)
Speedo seem to not register the proper speed, my wife who was following me said I was going 5 to 8 mph slower than I thought I was going. So the speedo seems not to be calibrated (I will search forum on this)
The K 75 throttle had no return resistance on it like the K100. I can let go of the throttle on the K100 without loosing speed. For Peggy, I will look for hand protectors, heated grips. She also thinks the handle bar postition is too forward.
The experience of having ridden both bikes for the first time was great.
Thanks again for the input.
Jim
14Back to top Go down   Peggy's K75s Empty Re: Peggy's K75s Sat Mar 23, 2013 10:26 pm
The low cost alternative to heated grips is Hippo Hands an insulated cover for the hands and keeps the rain off, don't look great but really keep the wind off, or get heated gloves which are more effective than grips because the grip only heats the inside of the hand and fingers and it is the outside that gets cold.
15Back to top Go down   Peggy's K75s Empty Re: Peggy's K75s Sun Mar 24, 2013 5:21 am
MikeP
MikeP
BMW put some (usually three pads) of foam between the instruments and the fairing, front centre panel. These crumble away or disappear in some other way.
I use a 3M self-adhesive foam tape in its place. It stops the bouncing without holding it so rigid that the insides get shaken to bits:
Peggy's K75s BMW%20K75S%20%28347%29-L
Peggy's K75s BMW%20K75S%20%28348%29-L
tio Jaimito wrote:The K 75 throttle had no return resistance on it like the K100. I can let go of the throttle on the K100 without loosing speed.
Jim
There's a cheap fix from BMW (and some other suppliers). Some may call it an early cruise control, others call it a throttle stop screw:
Peggy's K75s K75S%20%2886%29-L
Look under the throttle assembly and you should see a pale coloured plastic plug. Skewer it out and the thread is there to take the screw.
Peggy's K75s K75S%20%2885%29-L
It's a simple friction device, adjustable for how much resistance the rider wants in the throttle return and (here at least) very cheap.
BMW Part# 32 72 1 454 414
