Number of posts : 7967
I did mention remove both connections. If only the earth is removed it is possible if you are using an uninsulated screwdriver to then earth the electrical system accidentally when removing the metal plate over the battery. I know because I did it. If you remove both connections then this does not happen. If you are taking out the battery they both have to come off anyway.
I am not sure mine is standard but a philips screwdriver opens both from the left side [the right hand one cannot be opened from the right because of the coolant expansion tank bottle.] Reaching from the left side across to the positive which is on the right with an uninsulated screwdriver leaves you very close to the earth terminal and the frame.
1971 Yamaha 125 YAS-1
