1 The light control (Right side) Tue Apr 03, 2012 4:39 am
komandoalicante
Here's the light control (Right side) on the back we will remove the piece that holds the wires, removing the screw marked with arrow
Removing this screw allows us to pull the turn signal switch to remove
Now let's remove the screw holding the button turn signal cancellation. You have to pay special attention, because in this hole there's the light switch screw marked with the black arrow, note that the cancellation is in a vertical plane while the light is in a horizontal plane.
This is the position of the screwdriver to remove the screw-flash cancel button
When you start to loosen the screw, you must be careful to hold the button, so do not jump the ground and slip
In the button you can see the pier and slip switch
And what is your position.
Now you can see the screw on the remote control of lights, as I said this is in a horizontal plane.
Never remove the screw holding the plastic before.
Carefully remove the slide it is below the pier and the steel ball.
The steel ball is often left in the hole, look carefully.
When you remove these screws has been very careful with contact steel ball and spring brass
Now carefully lift the white slide
You can see the spring contact and the ball
Your turn to clean
Dismantle the emergency stop
With a small screwdriver you a little leverage
Remember holding work when removing red cables, since the part which is also very sensitive
Do not miss these two springs
As the cable sheath is too damaged, you can put some heat shrink, we need to remove the connector
With a small screwdriver do a bit of pressure to bend a small tabs that keep out the contact back. Look at the following two photos
By pressing the tabs have collapsed, allowing passage through the plastic connector
Now we have to open the tabs, so that when we insert the contacts into the connector, are set
With a little patience is out the connector.
This is the reason for removing the connector
Apply heat
Cleaning and lubrication
That's how the contacts were dirty
I had a problem with the intermittent contact
We pulled the pin
The dirt was widespread, clean and assemble
More cleaning
We cleaned
Clean and lubricated (Vaseline)
Clean and grease
This part is very delicate, the contact is easily damaged, and if you lose your way will cost you to make it work well so arming you patience.
All clean and ready for lubricating oil on
Already lubricated and cleaned contact
You must be very careful when mounting the slide with the contact and spring, spring ball and the ball, holding the whole loosely and put the screw.
The ball is under the dock
We present the slide while holding the whole
And finally look with screw
EThis is the smallest screw, if you put another in his place, you can remove the front and not look good.
We will mount the flash cancel button, you can now take advantage of and clean up a little, well, you can carefully review the outline of the symbol, with a permanent marker.
Hold it while you put the screw
Remember that in this there is the sliding screw the lights but on another level.
And finally put in place the right turn signal button and screwed.
this. this, this is all folks.
Regards
Your turn to clean
Apply heat
We pulled the pin
More cleaning
We cleaned
Clean and grease
Regards
SAK3 and komandoalicante is the same person
In March we made a International meeting KEDADA ALICANTE of BMW motorcycle K in Spain.
The last meeeting March 2020
https://youtu.be/hfqxlGeEVsY
